I am showing pedal smoothness and torque effectiveness, but the fields are both showing as “- -“
I am however getting balance #%- #% with numbers.
what has to happen to show PDL SMTH and TORQUE EFF?
1887614 you will need to check two things.
1) Make sure the pedals are paired via ANT+ and that you are seeing that the pedals are both paired (i.e. L/R)
My Rally Power Meter Pedals Is Not Displaying Cycling Dynamics Data
2) Make sure Torque Effectiveness is enabled in the Sensor Details
What is Torque Effectiveness and How Is It Calculated by Garmin Power Meter Pedals?
Garmin and Favero are similar. In fact, Garmin invented the Cycling Dynamics then gave it to ANT+ to be included in the ANT+ feature so any manufacturer could use it as a member of ANT+.
The button to turn on the TE, or torque effectiveness, won't be visible unless your garmin 530 is on and has recognized your pedals which must also be on and paired. Otherwise, the button to turn on TE will no be seen.
...and being Clear - a Division of Garmin Canada, Inc., who acquired it from Dynastream; all discussed in a different thread. But not important to help the person who wants to know how to Turn on TE. It is interesting that Garmin seems to be consolidating many innovators into their cabal much like the recent acquisition of First Beat Analytics.
