New Edge 1040 Series Public Beta 14.12 Now Available
A new Beta software for the Edge 1040 Series has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
https://www8.garmin.com/support/agree.jsp?id=15990
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Change History
Changes made from version 12.16 to 14.12:
  • Added support for Ebike Smart Range
  • Added Music Control widget
  • Added support for Intensity Minutes
  • Added support for Fitness Age
  • Added climb markers to elevation graph
  • Added support for the Tempe temperature sensor
  • Added support for Connect IQ glances on the home screen
  • Added Segment Time data field
  • Added support for startup.txt
  • Added support for turning off Daily Suggested Workout on main menu
  • Added support for returning to training loop using Di2/Edge Remote buttons
  • Improved capitalization behavior on the keyboard
  • Improved turn prompt responsiveness
  • Improved auto-pause responsiveness
  • Fixed issues related to Connect IQ
  • Fixed issues related to Real Time Settings
  • Fixed issues related to solar gain reporting
  • Fixed potential freeze with specific map locations in Europe
  • Fixed issues related to map zooming
  • Fixed issue with disabling turn guidance
  • Fixed various bugs and improved product stability
Changes made from version 12.15 to 12.16:
  • Fixed Di2 missing Full Synchro Shift front ring change warning
  • Fixed WiFi password text entry limitation
  • Fixed Right Power Sensor Missing error text
Changes made from version 12.11 to 12.14:
  • Fixed sensor dropouts when using Connect IQ data fields
  • Fixed Power Guide not working for users with high FTP
  • Fixed workout page being removed from the timer loop
  • Fixed segment data screen data fields
  • Improved product stability
  • Did a ride this morning, and seemed fine EXCEPT I was getting RTL510 radar disconnects/reconnects maybe 6-7 times per hour. Much more than normal. I'll delete the light network and see if it stays that way on a ride later today.
  • Just checked, still not working:(
    I advise you NOT to buy this product if you have a 4iiii p3.
  • Where do i find the "Music Control widget" on the Edge 1040 Solar with this beta (German Language settings)?
  • It is a widget that you need to add to the widget control loop that accessed via swiping down from the top of the screen.
    To add it via the Edge got to System -> Widgets -> Plus Icon -> Music Controls
  • Answer myself: I have to enable it in the APP.
    Or like @aweatherall answer me : To add it via the Edge got to System -> Widgets -> Plus Icon -> Music Controls
  • Thanks for the beta. Installed fine last night and figured out how to take off the suggested workout.
    Hopefully this fixes my 1040 solar where when starting it will say unit it overheated even though it was 60 degrees. Restart fixed it but annoying.
    Also regarding tempe why dont you use “windfield” data app as it is much more accurate for everyday use even though there is a $7 or $12 yearly cost depending on what you want
    Have to say the screen size has spoiled me and used my 530 yesterday mountain biking and seemed crazy small.
  • Wohoo, Tempe support
    Wohoo, startup.txt support
    Wohoo, Music controll support
    Thanks for adding those things! Lets see if it even resolves my issue with workout screen staying blank at daily suggested workouts.
  • I am satisfied. I had no radar disconnects.
    Auto pause working, no lag. Intensity minutes working. No freeze during ride. Daily suggested workout dont work, but this dont disturb me.
  • ¿Se sabe algo sobre el cuadro negro en el gráfico de desarrollo del Di2? ¿Está solucionado? Gracias
  • Is daily suggested workout synced with the Epix? My edge suggests a base workout wich is empty. Also, in the activity the workout screen is a blank screen as on 12.16 if I use the suggested one.
    I can imagine its because my Epix knows about a Primary Race day wich is a run and does not want my to do any training rides until then. :-D
