After updating my Edge 1030 Plus to version 6.30 I am experiencing more frequent and severe sensor dropouts. Prior to the update the Varia radar would "disconnect" a few times during a 2 hour ride. Now its happening 15-20 times per ride. Also the power meter is dropping out which did not happen before. Additionally on the last ride of 90 minutes the entire computer shut down and rebooted during the ride. There seems to be a problem with the update that is causing more frequent and severe dropouts I encourage you to fix quickly. As I read prior posts this seems to be a continuing problem. Do you know what is causing it and what it will take to correct it?
