I selected Europe as the only region I want to install on my device.
However, GE keeps insisting on informing me that I can put additional maps onto the device- is there any way to remove this prompt?
This has been escalated with new Express logs on the latest version. I will update this thread when I have more information to share.
This is still an open ticket and I apologize for the lack of info. I understand it is frustrating to hear "we are still working on it" over and over, but it is also frustrating to hear nothing back.…
For folks seeing this issue in Express, could any of you provide a screenshot of what you're seeing exactly?
There is a lot of good description in the thread already, but I'm just looking for any additional…
Same issue here – super annoying.
Garmin Express informs me again and again that 5 item need to be updated. After successful download (either one or all five) the update(s) are applied. Then the…
I have called Garmin Support it's an issue with Garmin Express, I was told it should be fixed in the next GE update.
Seeing this as well. Tells me I have 5 maps to update. Over and over.
New version 7.3 for Windows too. Shame it still just goes round and round in circles. Says "Updates Available", so you press "Install" and it then takes you back to a screen that says "Updates Available"
There is a lot of good description in the thread already, but I'm just looking for any additional details to help escalate this issue.
Happy to help. Step-by-step screenshots in attached PDF along with directory of my Garmin. I'm Technical Director for a software company, if there's anything you need me to do, just ask on here or directly.GarminSyncIssues (1).pdf
I asked Garmin Express to check for updates, and it told me Version 7.3 for Windows was available. I upgraded, and installed the current Trailforks map. That seemed to work, so I unplugged the Edge, closed Garmin Express, and started again. This time, I had only two updates - North America and Europe. I installed the current North America map successfully, I'm leaving Europe for another time, since I cannot travel currently.
Everything seems to be working for me at the V7.3 level of Garmin Express.
forgotrafe, maybe you need to disconnect your Edge, close Express, and start over. I hope it works for you, too!
I edited my post to remove the check mark on "Suggest as Answer". I don't know why it worked for me, and leaves others hanging.
Tried all those things and nothing gets me out the loop.
Stevenciu - that video is exactly the behaviour I get, including the empty Manage Maps screen.
