Garmin Express- continued prompts to update maps
I selected Europe as the only region I want to install on my device.
However, GE keeps insisting on informing me that I can put additional maps onto the device- is there any way to remove this prompt?
  • I have applied a "workaround" . . . Not very elegant but at least all my cycling maps are being correctly "seen" by Garmin Express. I went onto "Map details" and selected "reinstall map" for the three maps that were already installed (and up to date).
    There must be a better way than this but it worked for me.
  • This is the actual solution - Garmin Express allows you then to remove those maps. It also shows them in different colour from the "base files" (which it considers unmodifiable). Somebody mark that as answer…
  • I am on a Mac and using GE 7.1. I can select maps under 'Manage Maps' to be deleted from the device but when I get a screen saying'Ready to Apply Changes estimated install time 6 hrs' and on the next row 'Change Summary - Delete - Map :Routable Cycle Map of South America 2020.10'. I press continue and get an error 'Applying changes and another window pops up saying 'Error some changes not applied : retry or continue?'
    Why? I only want to have EU maps at the moment.
  • Im on 7.2.0.0 and I get the same errors when trying to manage my maps.  Downloading and never actually successfully updating my Edge has now filled my Macbook.  Why is downloading so painfully slow?  Is there a cache I can empty?
  • For me it was resolved few month ago, but the problem now re occurred . I am on Garmin Express 7.2.0.0 on an IMAC.
    Annoying it is back again
  • I'm experiencing the same issue with map updates on Garmin Edge 1030 Plus on the latest version of Garmin Express (7.2.0.0). Infinite loop of saying I have updates to install; starts installing; gets 50 percent of the way through the download; fails; says I have updates to install; ...
  • Same here except in my case installation never gets started. Endless loop of garming express telling me I have updates for the Garmin Edge 1030 Plus. I updated my Garming Edge 530 without issues.
  • I also had the same problem for a few weeks, but yesterday everything unlocked and the routable cycle map of europe 2020.20 was downloaded and updated
  • Well turn by turn on saved courses  does not work for me ! I missed all my turns ! I bought the 1030 plus to do gravel riding and can follow my course ! very very bad
  • This problem has occurred for years. No update has taken it away. With my Fenix 5x nothing I did would fix it. So I stopped using express for a while. I eventually bought a Garmin Edge 1030plus last year on the day they were released and have had the same problem with it ever since I got it.
    Today I updated Express to the latest version and I had to re-add my devices. My Fenix 5x sync'd and updated without a problem, however my edge 1030 plus still fails to do so. I have given up trying to remove the maps in other countries that I don't use. I am only interested in Australia and NZ, but cannot remove the other maps, and only update my local maps.
    Sounds like Garmin need to get their act together and fix these silly issues. I know it isn't hard to do. I am a software engineer and do this kind of thing day in day out. You see a problem (bug) you fix it. I can appreciate that some issues are harder than others to fix but this seems like it would be one of the easier ones to fix.
