• Battery Drain - Venu 2 - probably others.
    I've had the Venu 2 for quite a while now and have noticed a pattern related to battery drain.
    The watch drains roughly at 10% per day, sometimes a bit more, depending upon what I'm doing.
    However I can guarantee that after listening to music…
  • RE: Venu battery drain is unacceptable
    Until yesterday, I could get a day and a half with medium brightness, always on, and oxymeter on. I believe there was an update issued yesterday (July 22, 2021), and now I get 4 hours. Your post predates the update, but it’s possible that a fix for the…
  • RE: battery drain after gps activity
    After today's walk I took some extra care to see how I'm supposed to close out of an activity.
    I noticed that on the summary screen you can swipe up from the bottom and choose 'Done'. This has made the GPS close off correctly and…
  • Battery drains quickly in AUTO mode (SatlQ)
    Versio 15.77 - In the AUTO mode of the satellites the battery drains too quickly. In a 3-hour activity in the mountains, with very little closed area and clear skies, it lost between 12% and 14% battery.
  • RE: Massively increased battery drain since 13.37
    I would try to call, or use the chat option. Email is not always reliable nowadays.
    BTW, you can also try the tips in the Troubleshooting guide for high battery drain, it does often help.
  • Garmin 955 solar battery drain after update 12.23
    My 955 was working great, no battery drain issues.
    Updated to 12.23 and now have severe battery drain.
    Seems to be from the watch constantly syncing with GC.
    I can disconnect watch from phone and manually sync and the problem stops but that's is not a…
  • RE: Battery drain after update to 5.38
    I had issues on 3.40 (I've been on that firmware since October when I got the watch). On Friday last week I updated to 5.38 and I've been fine.
    However, when I was on 3.40 I had the battery drain issue many times. I uninstalled all third party…
  • Battery drain in power saver mode
    I have the fenix 7 standard edition and despite putting it in a stringent power saver mode with all features toggled OFF and without doing ANY activity - battery drains down to 15% in a day. With a full charge the saver mode shows 57 days but it actually…
  • RE: VA3 battery drain after in GPS mode
    Hi, do you also experience rapid battery drain without using GPS. If yes, may be this is connected with experience of other users / other recent thread, see
    https://forums.garmin.com/sports-fitness/healthandwellness/f/vivoactive-3-3-music/258133/significant…
  • RE: 22.10 HRV on and battery draining
    I never doubted the existence of bugs, accuracy issues or battery drain. It's just that you jumped to conclusions about Log HRV and HRV Status and are still digging in your heels, even though both are unrelated.
    Cheerio. V
