I've recently noticed faster than normal battery drain. 12% in less than 24 hours.
If you are seeing a crazy battery drain, you'll probably see the same if you have no CIQ apps on the watch. It's a firmware issue.
CIQ just passes on what the FW thinks
While a CIQ app can increase battery drain, resolving/minimizing that would…
Has anyone fix problem with battery drain? It seems like gps working all the time or something like that, my battery is drain about 3.3% per hour, and it about 30h, that's awful.
I expected battery drain when battery is under 40-45% whit my venu 2.
when it is fully charged, it seems ok and the battery drain just 0.6% per hour. but under 45% it drain so fast.
please could you release a new beta to fix this or I have to come back…
Hello,
I’m on version 19.30, and in the past 28 hours, my Epix Gen 2 battery dropped from 100% to 83%, which is far below the 24-day battery life indicated when the watch reaches a full charge (which I know it's only an indication, but nevertheless).…
Enrolled in the beta some days ago on Epix pro 51mm and battery has gone from 10 days to 3 days max with all settings being equal. Tried powering off and on but the battery drain still persists.
Battery draining quickly after latest update - I'm on version 16.22 Fenix. Battery drain same even when in battery saving mode.
I have battery drain problem after the latest software update. Battery from 100% to 0 in just 1 day.
How to resolve the issue
Watch: Garmin Fenix 6xpro
Software: 26.00
Battery drains rapidly after last update (from apx.14 days to 2-3 days)
