• Fenix 6s Battery drain fast
    Hi, I have bought brand new Fenix 6s about 2 weeks ago. Today at the morning when I wake up my battery statistics was at 65%.After 2 hours I was ready to start the running workout and when I look the watch  it was at 11%. It was about 50-55% difference…
  • RE: Battery drain issue -instinct 2 solar
    Sounds very much like a faulty watch. In 24 hours I got a battery drain of ~5%.
    I would suggest to contact the Garmin support
  • RE: Garmin 530 Battery Drain while off
    This morning the percentage is 100%. So this time there was no battery drain while powered off. Good news, I hope it will be consistent
  • Battery drain issue (?)
    My fenix 7X Pro SS is rather new (since the end of September), after the first full charge I was at about 30% after 2 weeks of usage (pulse ox on during the night, wifi on) - so it's around 5%/day. Now I'm on 15.68 and now I'm at 30% again but this time…
  • Rapid battery drain
    Since version 4.5 landed on my vivoactive 3 music, I can not get more than 2 days battery. This is with just normal tracking, no GPS. I've done a full reset and the issue still exists. Do I need to return it or is there something I can do?
  • Massive Battery Drain
    22.80 loaded onto my watch yesterday evening. In less than 24 hours the watch has lost 28% of the battery and I did one hour long strength activity and a 30 min elliptical. I've reset the watch but it's losing over 1%/hr. Before the update I would lose…
  • RE: Battery drains in 3 days ?
    Is the always-on display active? I get about three days with AOD on, so that seems in line with my experience. I've never used the watch with it off, so I can't say how long it will last with that configuration. All-the-time PulseOX measurement will also…
  • Massive Battery Drain after v5.50 update
    Something is going on. I am phasing on my 945 always massive battery drain since last update. For example with a 50% charge, one short 30min run and next day down to zero. I am using the watch since it hit the market and never seen this behaviour. I‘ll…
  • Battery draining fast only in sleep state
    I have using Instinct 2 solar (V9.24 (b56ce72). Noticed battery draining almost 10% when I wake in the morning.Only Iam in sleep. I have running only heart rate. Pulse Ox not active in sleep. If I do walk using GPS active, Battery not draining quickly…
  • RE: Battery drain
    Hi, I am having a similar issue with my Garmin Venu SQ Music. The battery now only lasts 4hrs while using the GPS for a running activity. No music feature is used so this duration is abnormally low compared to past performance. Is there is a solution…
