The battery consumes 20% in a day when with the same configuration it consumed 10% before the update.
Huge battery drain with the most recent update.
Today morning my Garmin Fenix 7 Solar battery was draining 4% per hour. I had not made any changes in the watch, the battery was just draining. Reset with light button didn't help. Finally I installed the latest 9.33 update, and now I'm back in under…
Because of this, I believe the high battery drain is more of a firmware issue rather than a hardware problem
If you tell the consumption remained the same even after downgrading the firmware, then I do not understand how you came to this conclusion…
I've had the FR255 for 3 weeks now and battery drain is very rapid. It constantly losses 40% a night alone, and it keeps on loosing connection to watch when customising data screens. I'm in contact with support but they're not understanding and I'm going…
I just bought forerunner 970 over 965. My 965 easily went 10 days but 970 barely sees 1.5 day, i updated to 6.17 version but there is a problem i cant solve with the battery. what can it be?
After installing 26.91, I have noticed that the battery drain in standby is about doubled in comparison to former versions. While I normally get ~12 ... 14 days battery life without activities, I now have ~ 7 days. Unfortunately, I have been able to reproduce…
Garmin Connect is killing my phone battery. Battery usage for last 24 hours has been 14h 31 min in the background. This happens way too often with this app and the only solution is turning off location and background app refresh, essentially neuterin…
