• Garmin Connect (iOS) battery drain
    I observed, that during ride with Edge 540, my phone battery drains a lot. Edge is paired to iPhone 13 Pro. Today after 3.5h ride, the Connect app consumed 32% of battery.
    I was not using LiveTrack or GroupRide.
    Can I change some settings to mitigate that…
  • RE: Battery drain or display problem
    I had by default Do not disturb during sleep from the very first day using the watch.
    However I had 40 % battery drain one night.
  • battery draining
    Since about two weeks ago, my Garmin is losing its battery charge at a much faster rate than before, about 20% per hour. In the past, I've ridden for 7+ hours without a problem. I have not changed any settings in the past two weeks, nor added any devices…
  • Battery Drain since Update 11.64
    Hallo,
    I never had problems with unusual battery drain till the latest Update. The Fenix 8 Amoled 47 mm usually lasted up to 10 day with activated Puls OX during night. Now I went from 100 to 30 % within 60 Hours without any activity.
    Anyone else having…
  • RE: Battery drain overnight/during activity
    I have the same problem. Overnight more than 13% battery drain. Phone disconnected due to Bluetooth and put in night mode. During the day it also drains heavily.
  • Battery Drain Use Case
    I have a Fenix 6X Sapphire, running 23.84 beta; I am normally losing around 3.5% of battery capacity per day, without activity. Few days ago, this increased a lot with more than 15% during the day. I noticed 2 things:
    1. I find the watch was stuck in synchronisation…
  • Forerunner 645 Battery Drain
    I have my 645 (no music) for a good year now iirc and never had any problems with the battery. But since yesterday, I have massive battery draining issues. I charged it 2 days ago in the evening and notices yesterday morning, that it was low again. So…
  • Enduro - battery drain
    Hi. I created battery draining table for my Enduro device.
    date charging started charging finished charging time (min) running (GPS)
    (h:min)
    walking (GPS)
    (h:min)
    other (GPS)
    (h:min)
    Total (GPS)
    (h:mm)
    other
    (h:min)
    total activity time battery discharge…
  • RE: 14.20 still having battery drain issue
      Please reach Garmin Support if you are still experiencing battery drain with software to version 14.20, if the steps in the following article do not help: Increased Battery Drain After Updating Software
  • RE: Battery drain after installing 4.5.3
    A few weeks it went well, but since three days the battery drain is worse again. I went to sleep with a full battery and this morning I had 62%.
