100% at 8.00 in the morning, 94% at 15.00.
No GPS, no activity, no notification, only HR.
I’m so disappointed, the only working firmware was 13.51 beta.
You may know this already but when charging reaches 100% you may a rapid initial drop as it is difficult to measure %100 when charging. Either make sure you have left it on the charger for a while at %100 or die you testing from 90 or so. As just suggested as well do a soft reset after an update. I have not had the battery drain issue on either building but those that did seem to be reporting much better results now.
So, here's a good one - over 15 days ago I posted Every single time... BATTERY DRAIN, specifically referring to the recent update to 14.20 by stating, "Why is it that every single time I install an update to my Fenix 5. I have to deal with the battery drain issue - serious, you think they'd have it figured out by now? The best part was the response from Garmin-Heath, it said I should update to software version 14.20!
I am NOT having a problem -- didn't with the previous 14.x versions and haven't recently.
I lose a couple tenths of a percent per hour idle, more obviously with more-serious use. I ran a half-marathon Saturday and consumed the expected amount of power. I have three different watch faces I like and they DO impact the power consumption -- Actiface appears to use the least, but I like it the least, so.... yeah.
Melegna Please reach Garmin Support if you are still experiencing battery drain with software to version 14.20, if the steps in the following article do not help: Increased Battery Drain After Updating Software
