• Garmin Venu 2 battery drain
    The problem with venu 2 battery drain.
    Hi. I have noticed that my venu 2 has BIG problems with battery drain. It's getting worse and worse. What I have noticed is that when a watch has like 60-70% of battery it instantly drops to 10% (not always, but…
  • extremly battery drain during the night
    Since 6 days, every night the battery drain is around 50% each night.
    Garmin please fix this problem.
  • SW 3.90: 50%more Battery drain
    again in this Firmware Release the Battery Drain is very high, more or less 50% more then usual before, use everything with standard settings as delivered, only Spo2 Measurement during night, instead of 7-8% battery drain a day i have now 16-19% a day…
  • Battery drain while device off
    Why is my Messenger battery draining while the device is off? It was 100% when I powered it off, now 24 hours later I power it back on and it's at 95% How does it lose 5% when the power is off?
  • RE: Battery drain overnight is amazing
    Same Problem: Just installed gc on my new LG V20: 40% Battery drain in 2 hours 30 doing nothing on the phone except having gc running. GSAM Monitor said gc caused heavy battery drain. I deinstalled gc and battery life is normal again. Same thing happend…
  • Increased Battery Drain after 12.20
    While I haven't quantified it, it just seems that my battery drains much faster after 12.20. in the region of 40% in 3 or 4 days where I used to get well over 2 weeks before. I wonder if others have this problem ?
  • Battery drain issues with 955
    Hi, I have noticed that my forerunner 955 has the battery drained overnight despite going to sleep with 70-80% battery power. This doesn't happen frequently, however it's annoying because I start the day with 5% battery. This never happened on my old…
  • Battery Drain after update to 11.20
    Everything is in the title. 50% battery drain in 4 days without use of GPS since the last update
  • RE: Battery drain Fenix 5X plus
    When I only use my Fenix 5X Plus as a watch the battery drains at about 1.7% a day.
  • Battery drain on Version 2.68
    I believe I had the battery drain issue on my Venu SQ2 version 2.66 that others had experienced.  I noticed last week I updated to 2.68.  The two times I recharged with version 2.68 the battery went from 100% to around 80% shortly afterwards (within an…
