Yes, also experiencing fast battery drain, lasted about two days on last charge. All standard settings (I reset to try resolve it).
If you cope with excessive battery drain problems after a firmware update, then I recommend reading the tips in the following threads:
Guys, for everyone experiencing battery drain.
Go to garmin connect app
User settings
Set sleep and wake up times (AM) to something very close for example 0100-0115.
The reason you are experiencing battery drain is because of the backlight which turns…
There are some newer threads that are not locked. A lot of people complaining about the same thing, so there is definitely a pattern.
A couple of examples:
Since I updated (currently SW version 5.10) I noticed an increased battery drain on my watch. Just in SmartWatch Mode i usually have 0,3-0,5% per hour, now it's up to over 1% since the last charge two days ago.
Anybody else experienced this problem…
I didn't have to do that it powered off because of the battery. I charged it and worked ok. The problem is if there is a huge drain there should be a function or something that could 1) warn for high cpu usage on the watch 2) Reboot or kill the process…
Just bought a 945. I have it all updated to the newest Firmware, Software etc... I have turned off all Smart Notifications (I find them annoying from my phone) and essentially have the watch used as an everyday weararound option during the day, then obviously…
I got a Fenix 6s back in June and the watch had 9 days battery for 3.5 months. Suddenly in October there was a problem with the altimeter and the battery drained within 3 days. I assume this was due to a software update. As I could not fix the issue I…
