• RE: Battery Drain 11.28
    As far as I have noticed, most battery drain on 11.28 comes from keeping Bluetooth on all the time. I would recommend keeping it off for 1-2 days (and only turn it on to sync data with GC 2-3 times a day) to observe the battery consumption.
  • battery drain issues - watch replacement
    Like lots of other people, i had battery drain issues.
    Garmin replaced my fenix 6X sapphire.
    The issues are gone.
  • RE: Venu2s Battery drain
    I’m sorry to hear of the battery drain issues that you’re experiencing.  Let’s start by power cycling (turning off and then back on) your watch.  If the battery drain persists and if you have any Connect IQ (CIQ) Content, especially watch…
  • RE: Battery Rapid Drain
    There may be an issues with 3 party apps causing crazy battery drain.
    correct
  • RE: Overnight Battery Drain - 40%
    After removing CIQ apps/fields, I have not experienced the battery drain issue and closed it out with Garmin. One of the CIQ fields, Auxiliary HR, would search (by design) for a chest strap to connect, in addition to using OHR. So maybe that's related…
  • background and battery draining
    I don't know if it's a good place for such observation but I describe it here.
    Wf check if((phone_connection==true) && (data_is_old==true)) and then WF
    a. save in store info pending_request=true
    b. calls BAG.registerForTemporalEvent
    c…
  • Battery drain on latest firmware
    Hey, experiencing higher than normal battery drain, and some third party watch faces showing infinite number of decimal points for temperature.
  • Battery drain on Oreo
    Recently updated my Nexus 5X to Android Oreo and ever since my battery drains really quickly when using my Edge1000 connected to my phone running LiveTrack.
    Anyone else experience really high battery consumption following an Oreo upgrade?
    Exactly the same…
  • High battery drain
    Yesterday I saw for the first time the high battery drain issue, but I managed to get the watch back to normal.
    I noted that I've got a GPS sync imediately after opening the Run app. It didn't take the usual 10-20 second to sync the GPS. After running…
  • 17.16 Battery Drain Thread
    For those of you who are still seeing battery drain issue on 17.16, please read the following:
    We are still trying to figure out what is causing the battery drain.
    I'd like to get some fresh files from your watches so that I can investigate this issue…
