• Battery drain fix?
    Hi! Anyone who's experiencing sudden battery drain (approx 4% / hour?!) Mine was working perfectly well and started all of the sudden to drain the battery. There was no software update or anything like that. I have tried:
    - turn off bluetooth
    - turn…
  • Very bad battery drain 14.36
    Very bad battery drain 14.36...even it was mentioned this was fixed in 14.36.
  • Battery Drain Issues
    I've generally been happy with battery life (about 15% drain/ 24 hours and 13% per hour of gps use).
    However, I have noticed some erratic/excessive battery drain in the last few weeks.
    I finally decided to measure/chart the battery drain -- see below…
  • RE: 955 battery drain - 13.23
    Also turned off strava live segments and battery drain issue seems to be resolved.
  • 7.35 battery drain?
    Anyone else upgrade from 7.24 to 7.35 seeing the battery drain much faster? I am dropping about 10% per day with no GPS usage, minimal backlight and pulse ox only at night which is the same as it was previously. Previously I was dropping about 4% per…
  • Battery drain after activity recording
    Anonymous
    Anonymous
    After recording an activity using GPS, battery drains several % per hour until device restarted
  • 21.00 version battery drain issue
    Did any member here have a battery drain issue? spend 30% of battery for each day with save mode
  • Gauging battery drain.
    I know this has come up before, but...
    Short of just installing on device and checking battery level at intervals, is there really no way to gauge battery drain?
    I know watch faces with onPartialUpdate can view diagnostics when in low power mode, but…
  • RE: Battery drain on FR 255 - 2 day battery max - 14.2
    I am on 16.17 and am also experiencing faster battery drain than usual. during a 40min indoor no GPS workout I lost 14% battery
  • High battery drain 11.79ß
    Seeing high battery drain over the past few weeks. Only getting 4-5 days (with low number of activities) whereas typically I was getting >7days minimum during the summer with usually 4 or 5 days of exercise
