My lily goes flat overnight, since coming to the tropics (with higher daytime temps) my watch turns off randomly, the battery drains very quickly!! Any help?
So I've decided to switch off SpO2 and now battery consumption is 0.1%/h instead of 1.0%/h.
Strange thing is that I can't see system widget SpO2 (and no data in connect) but my watch face shows values but still 93% SpO2 but new values are put into…
My Venu 2 is draining its battery at 20% rate per day since I installed 12.07. Very annoying.
Even with one activity per day it lasted nearly one week before,
After installation of new firmware 6.00 i've noticed some excessive battery drain. Usually the battery consumption was 6/7% per hour. Now is 10/11%. Same sensors, same usage, same routes. Someone experienced the same????
i WATCHED THE BATTERY DRAIN. i DIDN'T KNOW THAT THE BLINKING GREEN SIGNIFIED THAT BUT THE WATCH IS BLACK ORDERED NEW CABLE STILL NOT CHARGING MUST BE BATTERY
Do you do a regular full power off or a 15 second reset power off? The second one always fixes battery drain after an upgrade for me.
Did a road ride yesterday with navigation going. Battery drained 8.9% in an hour. Is that normal? That seems pretty high to me, but may be normal?
After updating to beta 9.15 the battery is fully drained after 2 days only.
I use a battery widget that keeps track of average battery usage per hour for each recharge cycle and it's usually in the 0.7%-0.9% depending on how much I've used GPS.
