Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Potential battery drain culprit
    Garmin-Kevin
    Garmin-Kevin
    To participate in this battery drain discussion, please see the original post:
    Battery drain issues with 955
    • over 2 years ago
    • Running/Multisport
    • Forerunner 955 Series
  • Battery Drain
    Joolee
    Joolee
    I've identified the Garmin Connect app as being the culprit of severe battery drain on my Sony Xperia X Compact.
    A search tells me this issue has been raised on this forum before, but not for a couple of years.
    I recently updated the software but…
    • over 5 years ago
    • Mobile Apps & Web
    • Garmin Connect Mobile Android
  • RE: Excessive battery drain
    lindberg_a
    lindberg_a
    My 945 have had exessive battery drain for some time. I mostly do runs. Last week I deleted all the data pages for the Running activity, including 2 ConnectIQ data views. Then I added basically the same views from scratch. After that my battery drain…
    • over 3 years ago
    • Forerunner 945
  • RE: Rapid battery drain
    S.M.R.
    S.M.R.
    Also look here for some ideas linked to the reset methodology
    forums.garmin.com/.../13-21---rapid-battery-drain
    • over 2 years ago
    • Forerunner 255 Series
  • RE: Fenix 8 Amoled 47mm - Battery Drain
    Niterider4
    Niterider4
    For my Epix Pro, the cause of my battery drain was the Garmin Explore app I installed on my phone. The app kept trying to sync with the watch and I went from 31 days of battery life down to 3. It took me a while to figure out what it was, but as soon…
    • 7 months ago
    • Wearables
    • fēnix 8 Series
  • Battery Drain
    RunnerBeard
    RunnerBeard
    Hi all,
    Tactix 7 pro owner here,
    this is just to report that, unfortunately as usual, there is a huge battery drain as soon as the battery reach the "17 days battery left", it happens that it goes down to "11 days left" in just 8/10 hours.…
    • over 1 year ago
    • Wearables
    • fēnix 7 Series
  • Battery drain - 17.12
    tom_brisson
    tom_brisson
    My Epix 2 Pro needs to be charged every day after updating to 17.12.
    • over 1 year ago
    • Fenix 7/Fenix 7 Pro - Epix 2/Epix 2 Pro - Enduro 2 - Quatix 7 - Marq 2
    • Community Discussion
  • RE: Battery-draining bug: AOD updating every second even when in "low power" mode
    bluefish
    bluefish
    Gerd_NL said:
    I used both, stock watchfases and ICQ watchface, no difference in battery life and no special battery drain ....
    I personally don't know of any CIQ watchface that uses the battery as sparingly as build in watchfaces do.
    MOO5E said:
    Will…
    • over 1 year ago
    • Wearables
    • Epix (Gen 2) Series
  • RE: Battery drain
    sensovision
    sensovision
    Cranky K. said:
    The lipstick battery is so large compared to the 130 I only need to charge it once throughout the entire winter.  Unlimited backlight use on high, and it still lasts all winter.
    Can you share which one are you using or where you bought it…
    • over 3 years ago
    • Cycling
    • Edge 130 Plus
  • battery drain in version 13.15
    0810a4a8d3134a828c7e7f87c5a239fe
    battery drains fast
    • over 2 years ago
    • Fenix 7 Family - Public Beta Reports
    • Public Beta 13.xx
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
