• Edge Explore battery drains attached to charger
    Why does my Edge Explore battery drain when attached to charger?  I attached to a charger using the cable that came with the unit.  The unit had a battery level of 40% when I plugged it in.  Two hours later, the battery level was down to 3%.  The same behavior…
  • Battery draining Android vs. iOs
    Hi, I just moved from Android to iPhone and found that my fenix 5 sapphire battery usage (no activity) about .66 per hour or ~16% per day - it is insane
    since on Android it was 6-7% per day.
    however if I turn off the blue tooth on watch - usage 2% per…
  • Battery drain since last betas
    Since last betas, battery lasts less than in previous builds. Please, check.
  • Samsung Galaxy A20 Battery Drain
    I recently bought the Garmin R10 and I'm using it with the Garmin Golf App on my Samsung Galaxy A20 Android phone.  I have my phone set to conserve battery usage. The Garmin Golf App is identified as being a high battery usage app & I've noticed my…
  • How fast is your battery draining?
    Hi. I am curious about the battery life of my mk1. It drains about 1% per hour. Is it too much? I charge it every 3 to 4 days, with heart rate on, bluetooth off, least back light, version6.0, activity tracking on. .
    What about yours?
  • RE: Instinct 2s battery draining in 1 day
    instinct 2s refurbished
    Have you removed the first device from Connect? And did you also remove the old device from the Bluetooth list of your phone ? Did you do a reset on the new watch after installing the updates?
  • RE: battery draining within the day after update?
    Support said sometimes after updates those faces can have issues.
    Yes this seems to happen frequently. You would think there would be some notification process where developers are told of changes that might affect their faces Disappointed
  • Battery drain 17.17 an 17.19
    I upgraded to 17.17 : then noticed the battery issues but  randomly
    Tried to upgrade to 17.19 => even worst !
  • RE: BATTERY DRAIN FENIX 6X AFTER UPDATE HIGHER THAN 23.0
    I agree. The battery drain seems to get worse by every new update.
  • INSANE BATTERY DRAIN PLS HELP
    just charged my garmin 255 music to 100%. 40 minutes ago. 96% battery. no kidding.
    battery lasts 3 days and it's gone. I've  disabled garmin share, wifi, EVERYTHING.
    I've been asking garmin to help me, but I'm in brazil and they won't help.…
