• Strange drain battery Delta Tactical
    When battery is below 40%, the drain battery starts faster, yesterday tooked me 10% in clock Mode, today tooked 3% in 3hours. I have deafult watchface, I restarted  a watch and nothing helped. Everything started after update firmware to 19.20, mow I have…
  • RE: Battery Drain Issue with Garmin Instinct Solar
    Is this battery drain typical for the initial charge cycle
    My Instinct came charged, so if your was discharged, it is possible it stayed 5-6 years in the shelves (assuming it is really Instinct Solar 1st gen). If it is really that case, and…
  • Extreme battery drain 100% at 5am, 14% at 5:40pm
    I´ve only had the Epix for 48 hours. For some reason I can`t seem to figure out, the battery is draining at a very high pace. I have not done any workouts today and AOD is off so I would expect over two weeks of battery life, not just over 12 hours. The…
  • absurd high HR, insane battery drain. completely disappointed
    hi, guys.
    went for an easy run today. usual HR is 160 - 170. the watch reported 185 - 190 HR. I honestly felt like 170 HR, though.
    still facing insane battery drain. like, +25%/day drain a day. 1 activity a day. garmin share, wifi, ox disabled.
    firmware…
  • RE: Extreme battery drain Fenix 8 47mm (18h)
    Hello
    I am sorry to hear you are having trouble with the watch battery life. There are some steps you can try for this: Why is My fēnix 8 Series Watch Battery Draining Quickly?
    If this continues I would love to help investigate this further. Please…
  • Battery drain: is there a solution?
    Hi,
    Can somebody help me with my disappointing Garmin Vector 3 problem?
    Christmas 2018: I was happy with my new Vector 3's
    2019: I used them happily
    2020: Covid happened, didn't used them in the spring/summer. But in the fall I biked with some periods…
  • Battery drain after 3.70 firmware upgrade
    Hi,
    The new firmware upgrade drains the battery of my Edge 130.
    Same location, weather, connected sensors, mobile pairing, GPS settings, overall settings, etc. Everything exactly the same.
    3.60 firmware -> more than 12 hours of battery life
    3.70 firmware…
  • High battery drain 11.28 and bluetooth connection issues
    Since installing the 11.28 beta, I've lost 20% battery in 24 hours.
    Since a 100% charge, I've done the following activities with Sat-IQ enabled.
    Run: 55:24
    Walk: 31:35
    Walk 19:03
    In addition, I'm having trouble with the watch connecting to my…
  • Battery drain garmin fénix 6 pro solar
    Hello i have a garmin fénix 6 pro solar and have noticed that my Battery is draining really fast used to have 14 days of Battery life but currently im at a 5 day Max!!
    have the 24.10 Software and use my Watch every day for running And exercising…
  • InReach remote draining battery
    When the the Fenix 6s Sapphire is connected to an InReach device as a remote, it appears to drain the Fenix battery significantly faster. Even when not sending or receiving messages.
    For example, over a 12 hour period, the watch was drained 22% while…
