Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • Garmin Fenix 6X Pro battery drain
    bestsim
    bestsim
    My Garmin Fenix 6X Pro battery has just started draining at an alarming rate. It does not even last 1 day from fully charged. Software is 27.0. This has only just started happening. I did connect it to Garmin Express a recently, but not sure if it downloaded…
    • 5 months ago
    • Wearables
    • fēnix 6 Series
  • RE: Massive battery drain on Fenix 7s watch
    Yerk
    Yerk
    I had the issue of battery drain after GPS usage (if not rebooted or a non-GPS-activity was started) on my 7S pro ss.
    They replaced it with a new one which is working fine. So maybe the software has its issues but this may have been hardware related.
    • 7 months ago
    • Wearables
    • fēnix 7 Series
  • RE: battery drain in FW 2.80 very high 50% more
    f|33tStA
    f|33tStA
    this battery drain is more or less clear, there was a change by Garmin to use Pulse OX over a longer period greater then 4 hours during sleep!
    all other battery drains issues  are different!
    • over 6 years ago
    • Running/Multisport
    • Forerunner 945
  • 28.13 Edge 1040 Battery Drain
    ChrisF7
    ChrisF7
    After updating to 28.13, I've had the normally excellent battery life accelerate significantly (5hr ride = 45% remaining!)  I checked the auto screen brightness setting which caused it in a prior build;  it's set to auto.  Also checked GPS satt choice…
    • 1 month ago
    • Edge 540/840/1040 Series - Public Beta Bug Reports
    • Edge 540/840/1040 Series - 28.xx Bug Reports
  • Battery drain issue sorts itself out
    TheKayDee
    TheKayDee
    Ever since the v26.30 update, my Descent Mk2i battery had started to drain at the rate of about 45% per day, giving me 2 days of battery time, against at least 10 days previously. I tried every trick in the forums to come out of this including
    • a simple…
    • 4 months ago
    • Wearables
    • Descent Mk2 Series
  • RE: Watch Draining Battery
    4457719
    4457719
    In my experience battery go from 100% to 80% in 2 days and then it drains slowly. At least that is what i experienced. Still get around 9-10 days battery
    • over 2 years ago
    • Forerunner 255 Series
  • RE: Battery drain issues after 3.40 update
    Thank you Talahthas.
    I´m not using any custom watchface or any app, just factory (bad) software. Tried with restart and factory reset and same thing, actually the battery is draining at a 8-10%/hour rate using the device just as a watch, is really annoying…
    • over 7 years ago
    • Sports & Fitness Archive
    • vivoactive 3 Series
  • After upgrade to 16.17 battery drains 4 times faster
    SETM
    SETM
    Upgraded from 16.16 to 16.17 and battery consumption went from about 6% to 24% a day. Anyone else?
    Reported bug here forums.garmin.com/.../16-17-very-high-battery-drain
    • over 1 year ago
    • Fenix 7/Fenix 7 Pro - Epix 2/Epix 2 Pro - Enduro 2 - Quatix 7 - Marq 2
    • Community Discussion
  • Rapid battery drain on 20.21
    edlondon
    edlondon
    Drained 9% in a day with no activities vs 3% previously.
    • over 1 year ago
    • Public Beta Bug Reports
    • Public Beta Version 20.XX
  • RE: Battery drain after a fresh factory reset
    drkglb
    drkglb
    Thank you :! But no, PulseOx if off as by default. I found out something is probably wrong with post-activity power management, as happens for other users. see here.
    Battery draining - fēnix 8 Series - Wearables - Garmin Forums
    Definitely a software issue…
    • 7 months ago
    • Wearables
    • fēnix 8 Series
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
