FWIW, I have a D2 Mach 1 on 9.33. I just got the watch last Thursday and updated to 9.33 almost immediately. I am not having excessive battery drain at this point. I do not use strava segments, but I have done exercises with it.
Yes I have battery drain after update 5.50. Charing evening and morning. I gona try to reset my watch. Before I do this, is it necessary to disconnect the watch from the Garmin connect app at phone first and delete the Bluetooth settings in phone?
I was contacted by Garmin Support from this thread, but my issue seems to be BT connection related. forums.garmin.com/.../increased-battery-drain
My LEDs aren't working, both for HR and pulsOX. I guess that's the reason for my insane battery drain. Are yours working?
Hi, I have a Garmin D2 Delta which is based on the Fenix 5. Recently, the battery drains overnight and the watch shuts down at 4 a.m. each night (last monitoring of sleep and hart rate). When I go to bed around midnight, the battery is always more than…
I am sorry your battery is draining fast. There are a few things you can try. If your fast battery drain issue continues, please do not hesitate to reach out to your regions Outdoor Product Support to warranty replace your watch.
Please try the follo…
When will be some fix of battery drain?
There are a lot of threads regarding battery drain that may or may not help. Type "battery drain" in the search box at the top of the Fenix 6 series forum.
Garmin connect is draining Iphone battery from 100% to 60% in a matter of 30 seconds. This has only started within the last 2 weeks or so. What’s happened since the last mayor server crash of some weeks ago? It was all good/ok before the crash.
