Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • BLE on Simulator doesn't work with VS Code since SDK 4.0.7
    Charles
    Charles
    Apps debugged using VS Code using BLE emulator won't work as the initialization time of the COM port always takes longer than the timeout of the linking the debugger VS Code/simulator.
    In 4.0.7 changelog, "End the Visual Studio Code debug session…
    • over 3 years ago
    • Connect IQ
    • Connect IQ Bug Reports
  • RE: Why do I need to disable and enable my heart rate monitor at the beginning of each ride? Edge 530 & Garmin HRM.
    leginswal
    leginswal
    If I put my heartrate strap on and I am getting an intermittent reading, I will wet a finger and just run it underneath the strap where the sensors are, or take it off and give it a lick or just tighten the strap.
    Before putting it on, sometimes if I think…
    • over 3 years ago
    • Cycling
    • Edge 530
  • RE: fēnix 5x + AllTrails .gpx course fails to import both through iOS Connect & Garmin Connect web portal
    rockncrag
    rockncrag
    Please to hear you found a solution... What gets me is there should not be the need as Garmin should be able to use the files as is... But Garmin are not known for their software solutions and and fixing issues etc ;-)
    • over 3 years ago
    • Outdoor Recreation Archive
    • fēnix 5 Series
  • RE: Auto Step to next hole after back 9 first
    sssmw1
    sssmw1
    Seems like that was part of the last update also. I never had that issue before. I could always resume when going from 18 to 1.  This last update seems to have messed up a couple things.
    • over 3 years ago
    • Golf
    • Approach S42
  • RE: Vivofit 4 - Schritte werden nicht von connect gespeichert.
    brummnix
    brummnix
    Bei der Kontrolle der Internetseite von Garmin Connect habe ich festgstellt, dass das Gerät seit 21.1. nicht mehr als synchronisiert gilt. D.h., die App synchronisiert nur scheinbar, in Wirklichkeit aber nicht. Das Problem dürfte hier in der App von Garmin…
    • over 3 years ago
    • Mobile Apps & Web
    • Garmin Connect Mobile iOS
  • RE: Montana 700i/750i AAA Battery Pack???
    twolpert
    twolpert
    You will never see a (working) AAA battery pack for the 7x0i. As I understand it, the iR modem needs more power (peak power, at least) than a AAA pack can provide. Has to be a Li-Ion pack. It's not a matter of "Garmin doesn't want to", it's a matter of…
    • over 3 years ago
    • inReach
    • Montana 700i/750i
  • RE: calendar widget missing calendar entries
    9199166
    9199166
    Thank you so much for your responses and your suggestions. I really do not understand why I am only getting some on my watch. It really seems random which events appear on the watch and which don't -- the next event on my calendar doesn't show up, but…
    • over 3 years ago
    • Mobile Apps & Web
    • Garmin Connect Web
  • Suggestion: When ever the R10 does not measure enough metrics, the shot should not be used.
    rastam4n
    rastam4n
    When ever the R10 does not measure enough metrics, the shot should not be used in game. It has cost me several strokes in a round when the result of the shot did not match the quality of the shot, and every time this happens I can see on the screen that…
    • over 3 years ago
    • Golf
    • Approach R10
  • Over estimating distances
    2373139
    2373139
    Today I did a 6 mile run and it was calculated as 500miles, GPS tracking was accurate... Any ideas to fix?
    • over 3 years ago
    • Sports & Fitness Archive
    • Forerunner 45 Series
  • RE: Race An Activity not displaying correctly - 19.2
    Beetovy
    Beetovy
    Maybe it will help someone.
    It did factory reset. After it time Ahead/Behind starts work properly.
    • over 3 years ago
    • Wearables
    • fēnix 6 Series
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
