This needs to be fixed asap. On CIQ watchfaces, the seconds only show with a gesture.
I did not buy an MIP watch to do arm gymnastic like I did on my AMOLED watch. Please fix this immediately and do NOT let the seconds disappear...
But yes, this is a forum, and we can debate.
To make a request to Garmin... you must contact Garmin.
However, small points are easier to implement for CIQ developers, as the time available for a screen update is extremely short.
Be that as it may, as I've tried to highlight over and over…
It has everything to do with Garmin, as they are the developers of the watchface.
It's a pity that we can't find out which watchface your complaint is about. I therefore assume that the developer…
As far as I know, for both Forerunner and Fenix MIP devices, the built-in digital watchfaces have digital seconds
Not all
actually, those dots around the perimeter are digital seconds :)
That is a question of definition.
In the case of the watches, "digital seconds" means for me: a directly readable number is displayed.
For me, analog means that there is a "marker" (either a hand or a dot) that points in one direction and from which you can read the seconds.
For me, this are digital seconds:
As far as I know, for both Forerunner and Fenix MIP devices, the built-in digital watchfaces have digital secondsNot all
You are changing the intent / spirit of my statement by cutting it short. What I said was:
"As far as I know, for both Forerunner and Fenix MIP devices, the built-in digital watchfaces have digital seconds which are constantly visible and changing"
The point I really wanted to make was that as far as I know, on Forerunner and Fenix, for any watchface which has digital seconds, the digital seconds are constantly visible and changing. Here I will clarify that by "digital seconds", I mean numerals [e.g. "15"].
I wasn't even thinking about digital watchfaces which don't have "digital seconds" but instead have a graphical seconds indicator like you've posted. Yes, my statement can be taken to imply that all digital watchfaces have digital seconds, but that wasn't the point of my statement.
Like if I said "I heard that for some Fenix MIP watches, the built-in analog watchfaces have an analog seconds hand that disappears after a long time", would you then cut down that quote to "built-in analog watchfaces have an analog seconds hand" and be like "AHA here's an analog watchface which doesn't have a seconds hand at all!!!!!111!!" Obviously you would know I wasn't actually trying to make the point that all analog watchfaces have a seconds hand.
You know, this is the problem with trying to be too precise with words. The more precise you try to be, the more you open yourself up to have your main point undermined by people who argue against a secondary point. I mean, we've all done it, including myself.
If I had just said something like "MIP devices have permanent seconds" without specifying what kind of watchface or what kind of seconds, if anyone pushed back, it would've been a lot easier for me to say "oh what I really meant was..." (Yes, I'm aware I just did that anyway.)
I think it kind of sucks that being vague [intentionally or not] usually "wins" compared to trying to put forth a detailed, good faith argument, but oh well. Obviously I suck at arguing since I can't get my point across briefly.
And to be clear, it doesn't even really matter if not all built-in MIP watchfaces with digital seconds have digital seconds which are always-visible/always-changing. It's enough that some built-in MIP watchfaces are like that, because as far as I know, none of the AMOLED watchfaces are like that.
So to be absolutely clear, this is my argument:
As far as I know, on Forerunner and Fenix MIP devices, some (not necessarily all) built-in watchfaces have constantly visible and changing elements, such as digital seconds or HR. I don't claim that all built-in watchfaces have such elements, and I don't claim that the behaviour is exactly the same across all of the above-mentioned devices. For example, on my Forerunner 955, the analog seconds hand on built-in watchfaces is always visible and always changing, but I've heard that on Fenix 6/7, the analog seconds hand disappears after a long time [longer than 30 seconds].
Starting with 2017 MIP watches, It is also possible to implement such a watchface in CIQ, where some elements are constantly visible and changing, under certain constraints [can only use a certain amount of power, can only update part of the screen]
In contrast, as far I know, no Garmin AMOLED watch has a built-in watchface with always-visible, always-changing elements. I am 100% sure that no such watchface can be created in CIQ.
TL;DR
- For Forerunner and Fenix MIP, some built-in watchfaces have constantly visible, constantly changing elements. CIQ devs are allowed to create watchfaces with constantly visible, constantly changing elements
- To my knowledge, no Garmin AMOLED devices have watchfaces with constantly visible, constantly changing elements. CIQ devs are not allowed to create such watchfaces either
And my point is that even if one can argue that constantly visible, constantly changing watchface elements makes more sense for AMOLED than MIP, obviously Garmin does not think so. Garmin obviously thinks the opposite.
Be that as it may, as I've tried to highlight over and over again, built-in (native) watchfaces have fewer constraints and are more power-efficient than CIQ watchfaces. Meaning that what's possible / easy for a CIQ watchface may not necessarily translate to what's possible / easy for a native watchface.
But it seems like a few times in this thread, ppl have used the limits/behaviour of native watchfaces to justify the limits/behaviour of CIQ watchfaces. That's not necessarily wrong in all cases, but it doesn't capture the whole picture.
As I've said a few times:
- Until 2017, CIQ watchfaces for MIP devices didn't support "always active" mode, meaning they couldn't implement "permanent seconds". It's been said that the newer MIP devices have special hardware which allows for partial screen updates, and indeed, the mechanism for implementing "always active" mode in CIQ is to partially update the screen every second.
- But long before 2017, *built-in* watchfaces for MIP devices had "permanent seconds"
So if you bought a watch in 2015 (like FR235), (at least some of) the built-in watchfaces had "permanent seconds", while CIQ watchfaces could not have permanent seconds. Garmin didn't allow permanent seconds in CIQ watchfaces until they could source more power efficient hardware [*] to do so (seemingly to offset the CIQ "power tax"). [But notice Garmin was still ok with having *built-in* watchfaces* with "permanent seconds", even without this special hardware. Again this is a glaring example of native watchfaces operating under looser constraints than CIQ watchfaces, and not the opposite.]
[*] [This is kind of like how Apple only allows "60 hz" watchface updates in their newer Apple Watches supposedly due to a new, more power-efficient AMOLED display.]
Built-in watchfaces ≠ CIQ watchfaces
They may have similar constraints in some cases, but not all cases.
