If you check for an update, you might see this update available. I just installed on my 47mm AMOLED.
All right. The problem is still there. I rejoiced too soon.
Touch screen is not working after updated
Who knows.
Hopefully soon.
I still can't predict if and when the touch screen doesn't work. Definitely linked to sleep mode. But also sometimes after taking it off to shower etc. and also after charging…
Did you use the short cut or watch settings to set the Touch? Did you try soft reset, turning off then turning on the watch?
Thank you very much. After soft reset, everything works well as usual.
Confirming.. Touch screen is not working after night mode. Only when I turn watch off and on again then is working till the next night mode.
Same here. After new start it works for the moment, but after couple hours it stops again.
Well, this morning everything is back to normal.
I think the problem came from the update that was installed around midnight, just when the steps and floor counters reset to zero
Most likely , in do "not disturb" mode , you have set touch blocking .
Check in settings.
The issue happens on my watch (Amoled 51mm) since 13.32 again in 13.34 and 13.35 :
Touch is disabled if exiting sleep mode during "focus" sleep times. Restart AFTER normal Wake Up Time will fix it, but not before normal wake up time. I never had the problem before.
I reported the issues in the beta bug section.
Mine installed about an hour before midnight and everything reset as expected, steps, floors, calories, Intensity Minutes, etc.
This is an odd one, seems like an off-by-one bug, or possibly a clock-sync issue, hmm...
I'm really stock on my F8-Oled, only a couple of Activity fields this time (had a really bad battery experience towards the end of the use of my FR955, using a non-stock but well-rated face and a couple of other multi-fields for cycling), maybe a non-stock face isn't abiding by a reset value (not sure what order-of-precedence is/wins in the Garmin-dev world). This has been a bit eye-opening, at least in the month I've had it, zero battery issues and really only a few more obscure issues, things like where a slide on a screen requires a upper-right-button touch instead - annoying, but not really non-functional, yet (I'm sure now that I've posted this that the latest drop is going to give me a world of grief... ).
I have same issue after 13.35 update
Garmin-Laurie please look into it.
exactly like this for me, same issue.
