Hi!
In case watch display timeout is set to 15 seconds then ConnectIQ watch faces switch to AOD mode after just about 9 or 10 seconds. Some (the ones that try to draw basically the same image in AOD mode, for example, this one: apps.garmin.com/.../43ad29a2-10c7-4478-943e-bcdd73c700a7) switch to AOD mode in two steps - after 9-10 seconds the screen stops updating, after about 5-6 seconds more, brightness is reduced.
There is no such issue with 4 or 8 seconds timeouts - they behave as expected. Stock Garmin watch faces behave correctly not only with 4 and 8, but with 15 as well. This is clearly a Garmin bug and it seems to be the same (or very similar) to the one that was (or still?) affecting Epix Gen 2: https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/epix-2/335828/watch-faces-go-to-sleep-too-quickly-buggy-after-13-22
This is extremely annoying. In effect instead of 4, 8 and 15 seconds we get 4, 8 and... 9???
