New Update, new Bug in my Fenix 8 Amoled
There is no way to turn off the touchscreen during Activities. Not in the Activity settings or in the Focus setting nor thru shortcuts.
Please confirm
Cheers
Please confirm
Cheers
I was not able to reproduce this issue with these steps. However, I would like to help investigate this concern further. For this, I will reach out to you via Private Message to collect some specifics…
Hi,
If you need, I can send you a movie. At this moment I have an access to Enduro 3 with the same issue. I had Fenix 8 for tests last weekend and the same situation. My another colleague also. So minimum…
Doesn't work
Wierd mine work. Maybe a reset and re sync
When the activity is selected it is possible to use touch to move the screens in some non-water activities like running and cycling. Is this what is being seen?
However, once the activity timer is started Touch settings are honoured.
Not in my case. The display is always on, also after the activity started, no matter in which settings you turn it off
In which case try a reset.
That worked, but it's exhausting to reset the watch after every update
You might not need to.
Hi,
do you mean reset Garmin watch, not phone?
Did you do hard reset (factory default) or soft reset (long press LIGHT button)?
