Unstable bluetooth/ music playback
I listen to music on my watch through Spotify while running. The playback performs great when it's just headphones connected however when the watch is also connected to a HRM, the music playback is janky and cuts in and out constantly. I can only assume this is an issue with Bluetooth when both external devices are connected.
Note - I've been running with this setup on my previous Fenix 7 with no issue.
Please fix.
  • As I mention before this happens to me only when using GPS. No issues on treadmill.
    Things improved after a un-pair the headphones, reset the headphones and pair again with the watch. I have also changes the GPS settings to Auto-select (instead of Multiband as I did before).
    As I wrote, it is improving, but whenever I wam running next to high  buildings or under thick trees, music starts to jump bit.
    It is clearly for me a CPU issue. Watch cannot copes with both GPS and streaming.
  • This isn’t new it’s been an issue on every Fenix with music and you can find the threads in the forum. Garmin don’t acknowledge it and won’t fix it, and for some reason reviewers never acknowledge it either.
  • I have a similar problem. Running with chest strap and earphone-sony wf-c500, they are connected to the f8-solar, but when i want to change the playlist it is impossible. Presing the library buton and nothing. Even when i want to acces to music library when i finish workout, i cannot. Have to restart the watch and theh i have acces to library... Till next running
  • The same on Enduro 3. I tested with disconnected HRM and problem persists. I did the trick which fix the problem for a while - paused music for a minute then resume and it plays smoothly for a while but then lags again. I believe it is connected to lost Satellites finding. When it does finding it interrupts music. I used to use Fenix 6 Pro solar and never seen such an issue. It seems new software is not good enough yet. Need a fix.
  • Same for me.  Absolutely leaving Garmin if they can't get this basic stuff right.
  • Same problems! With and without HRM connected. Fenix 8 - 13.45
  • Running in a the city with skyscrapers and trees. IMHO the skip happens when the GPS struggle to get good signal -> it is a CPU issue
    It's probably not so much  a CPU issue but rather a 2.4ghz congestion issue (the frequency range bluetooth uses) when you're around thousands of other people attempting to use the same freqs with more powerful devices.
    The side of your head the bluetooth receiver is on also can plays a role as the signal is blocked by your body if the transmitter (the watch) and the receiver (your right earpiece) are on different sides of the a big bunch of meat.
    Yeah, you're likely indoors when you're on the treadmill and shielded from the countless other bluetooth signals outside. I've had the same issue and it almost always only occurs when I'm around thousands of other people in the city, never in the suburbs or the country.
  • Hmmmm...no really sure....with the AWU and same headphones (before switching to the Fenix 8) I had not issue....
  • Hello. We are sorry you are experiencing Bluetooth connection issues. Please review the following FAQs to assist in troubleshooting headphone connectivity.
    Bluetooth Headphone Compatibility for Garmin Music Watches
    I Am Having Bluetooth Headphone Connection Issues With My Watch
    If the headphones used have an additional footpod/Accelerometer sensor feature, ensure it is not paired as a footpod. (Look for "FP" in the sensor details of the paired headphones) Specific to Jabra headphones, we have this; Audio Cuts Out When Using My Jabra Headphones With My Garmin Music Watch
    Some customers have experienced an improvement to reception by temporarily disabling the watch's Bluetooth connection with their phone. This is not a permanent fix, but may help your experience while we investigate.
    If you are not seeing any improvements, our engineers would love to investigate this further. For this, please feel free to reach out to me via Private Message.
  • Update. I was able to fix the issue by updating the firmware of my headphones (Shokz OpenSwim Pro)
    totally sucks. I switched from Marq 2 to Fenix because of the issue with the headphones. Totally astonishing that the Fenix 8 has the same problem. Mine works well for 15 minutes and then consistently goes into stuttering mode
