on the fenix 7 I could select the maps to display in the map manager section. here I only see topoactive, cyty navigator, integrated map but i can not see and switch on/off my custuom map like OSM. an idea ? thanks...
Hello, I am sorry to hear you are having trouble managing which mapping is enabled in the watch menu. I would love to collect some specific examples of this concern. For this, I will reach out to you via…
The wide road borders issue is a firmware bug that Garmin introduced; I have released versions of my maps that fix this issue (until Garmin fix their firmware). All my maps now include the fix (same as…
Yes I have noticed that too. It is not possible now.
I cannot switch ON and OFF the different maps I have loaded like toasty toaster's map (which is for the moment plagues with the thick lines anyway).…
Maprando (from Alexis, France) over Talky Toaster over Topo like transparent layers.
"Sentiers des Berges" has been added by Maprando.
Now how can I choose, can I control which map I can see for…
on the fenix 7 i could select the maps to display in the map manager section on the watch. Here on the fenix 8 i only see the topoactive, cyty navigator, integrated map but i can not see and switch on/off my custom maps like OSM or other. an idea ? thanks...
Probably you have installed firmware update. We will have wait for next firmware release.
The wide road borders issue is a firmware bug that Garmin introduced; I have released versions of my maps that fix this issue (until Garmin fix their firmware). All my maps now include the fix (same as most other third party maps) and the issue also affects quite a few of Garmin's own maps.
Thank you. May I use your photo (cropped) to show my maps working on a Fenix 8?
Of course my friend, and if you need more just ask !
Now how can I choose, can I control which map I can see for an activity like I could do BEFORE the new UI. :-)
You can't until Garmin solve that bug.
It is just a missing menu in the activities setting. Not really a bug. ;-)
