on the fenix 7 I could select the maps to display in the map manager section. here I only see topoactive, cyty navigator, integrated map but i can not see and switch on/off my custuom map like OSM. an idea ? thanks...
Hello, I am sorry to hear you are having trouble managing which mapping is enabled in the watch menu. I would love to collect some specific examples of this concern. For this, I will reach out to you via…
The wide road borders issue is a firmware bug that Garmin introduced; I have released versions of my maps that fix this issue (until Garmin fix their firmware). All my maps now include the fix (same as…
Yes I have noticed that too. It is not possible now.
I cannot switch ON and OFF the different maps I have loaded like toasty toaster's map (which is for the moment plagues with the thick lines anyway).…
Maprando (from Alexis, France) over Talky Toaster over Topo like transparent layers.
"Sentiers des Berges" has been added by Maprando.
Now how can I choose, can I control which map I can see for…
It is indeed a missing menu/function.
So, it seems to be "by design" not just an oversight.
There are lots of requests to Garmin to add that menu/feature back into the new firmware for the Fenix 8/Enduro 3 devices; so far it has been ignored!.
If you want that functionality back, then raise it as a feature request or a bug (whichever you prefer).
correct, my mistake. Waiting for Garmin put that menu. RegardsIts strange because if its "by design" ¿how can indicate f8 I am using nautical chart?. Apart from that, some maps are listed and others are not. I forgot one thing. The f8 came to me with a firmware that did allow you to choose a map but a new firmware came out and it doesn't have the menu.
Hmmm, interesting. Maybe it was a mistake in the earlier firmware, or maybe it is a mistake in the current 11.59 firmware; let's see what happens, but I don't suggest you hold your breath ;-)
I have also spotted some other map rendering oddities, it seems that some POIs (in third party maps) are being replaced by the TopoActive POIs, even though the TopoActive Layer is switched off!
Which model, which firmware and which menu are you using (list button presses required to access that list) as I don't see that on 11.59?
Hi, it's previous firmware 11.59. Model is Fenix 8 47mm amoled. Here you can see:
https://youtu.be/lCYcNhrDLmc?t=215
