The DND-Mode on my fenx 8 doesn´t work. The settings that i change in this mode leads to changes from the general settings.
Anyone else with this issue?
Update September 13, 2024:
Our engineers are aware of an issue causing changes to the Do not Disturb settings to effect regular System settings. They are investigating this concern. And are looking to a…
Hello Steffen
I am sorry to hear you are having trouble with this. For this, are you adjusting the Focus mode for during sleep? Or what settings are you changing? How is this not working?
If you have not…
Sorry but DND is just plain broken hard reset etc. all the old tricks nothing happens. If you change your setting in DND it changes it globally which it shouldn't so it's DND it changes
Hello Steffen
If you have not already, I would recommend trying a hard reset. Then see if this is still not working correctly. For this, hold the Upper Left button until the watch shuts off, as opposed to selecting power off. Then power this on again.
Hello, exactly the same problem here. DND mode doesn't work.
Messages are supposed to come in without sound, but it doesn't do anything and the entire watch is set to messages.
It doesn't work even if you cover the watch with your hand. You can't delete the phone call list either.
Sleep plan no longer switches on energy saving mode.
Watch faces are terrible.
Hello Garmin-Laurie
i need DND for example when i´m in a meeting and the screen should remain dark and no vibrations.
I go into "settings-system-DND" where i want to change vibration, alarms, and so on.
But these changes do affect the normal behavior of the fenix 8 and not only the DND-settings.
I also recognized that when i turn on DND my screen gets lighter (which is normally set to low).
Hard reset doesn't help.
Same Problem here. Every setting you change in DND-Options is changed in the normal watch behaviour as well.
Same issue.
today im talking with suport they said im first person that said them that, so you need guys report this issue! Then they will open ticket and will repair that with next update.
Interesting for me, the muting of notifications works. But all other settings such as brightness dont work
