ECG is not visible, and I'm not able to set and used, INSIDE USA
Hello KRONK78
I am sorry to hear you are having this issue. You may consider connecting this with Garmin Express to check for software updates. Updates for the new watch have been being released nearly daily. Garmin Express
Hello Laurie,
Thx for the quick reply, and this was to solution
Best regards Kronk
Same problem.. solution fixed mine as well
Hi,
Is it possible to share the About info on the watch or through Garmin Connect Mobile ? WHR, FirstBeat, etc.
Also, if it works or when the CIQ App will be updated, i'm looking for Benchmark result to understand if Garmin change the SoC or if it's only "software upgrade" (i don't talk about pressure and speaker/mic features).
Thanks
fenix 8 51mm AMOLED. OS version: 11.59. Location: USA ( mid Atlantic ). ECG setup fails. In Connect ( on Android phone ) attempt to setup ECG while outside in an open area, searches for GPS. then Connect reports 'An error has occurred'. Garmin Express reports everything is up to date. Multiple updates have installed throughout the day.
Connect is up to date.
Have been using ECG for months on my Fenix 7X Pro.
Thank you Garmin. Apparently Garmin did some magic to get ECG working. That was the final peice I needed to make the fenix 8 my goto machine companion.
I just got my Fenix 8. I was looking for ECG feature and could see anything option. Thank you for this post, ECG is now working.
Same here, ECG cannot be found
Did you try following the instructions posted by Garmin-Laurie?
Hello BBK yes, i believe its because i dont live in the US ans that I dont know how to ensure my Connect app location is set to US….I guess I’ll wait until ECG is approved in Europe (the same as it is for the Apple Watch).
