I did an hike activity on Garmin for 10 days. I put it on expedition mode for the time. I see it on the watch but activity has not uploaded to Garmin connect or strava
Hello Sarah_1234
I am sorry to hear the activity is not uploading to Connect. This can indicate a corruption in the activity. Here are a few things to try.
Try syncing the activity using Garmin Express…
Hello I have the same issue,
If it won't upload to Garmin Connect using the manual upload method mentioned above, then this likely is due to the file being corrupt. Attach it…
Hello Sarah_1234
Try syncing the activity using Garmin Express. Garmin Express
If the activity is not uploaded, you may try manually importing the activity to the Connect account. You can find the Instructions: How Do I Manually Upload an Activity I Recorded to Garmin Connect? When trying to locate the activity, try the activities folder, but I also recommend checking the TEMP folder as well.
If this, is still not uploading, this would indicate a corruption in the activity. You can create a manual activity, but I would recommend deleting the original from the watch to avoid this negatively impacting the watch's operation.
Sarah_1234 did it work the workaround for you ?
If it won't upload to Garmin Connect using the manual upload method mentioned above, then this likely is due to the file being corrupt. Attach it to this thread. We can take a look to see if it is repairable.
thank you, synchronisation through a PC and with cable worked this time !
