Serious problems after update 27.00
After updating to 27.00 I've experienced the following issues:
  • After a first run with connected HRM Pro the heartrate-sensor stopped working. Restarting the watch (two times, if i remember correctly) fixed it. Additionally, the steps recorded by HRM seemed to not be synched with fenix 6 (TrueUp is active) and counted double in Garmin Connect
  • After a second run with connected HRM Pro the watch loses massive battery and the menu responds very sluggish - restarting it does not help :-(
As long as garmin takes to fix: How can i downgrade to 26.00? I did not have any problems with that version.
Thanks and regards,
Florian
/edit: problem was solved with replacing the unit by garmin support - not what I expected, but won't complain either. Hope all others having the same problem will get a firmware-update soon to fix it by software-change
