I went from a full charge lasting 5-7 days last week to a full charge lasting less than 2 days. I shouldn’t have to charge every day.
Yes my battery life has also been affected with this update(27.00). Is this another trick to lead us to upgrade to a newer device?
Same here. Since the update came through last weekend I lose 20% overnight while sleeping and am down 75% in 48h with only one activity that didn’t even require GPS. Used to last me a week full of activities…
Need to get back on v26 for the full battery capacity. Where can I find the v26 and instructions, please?
No, I'm not.
I've been on 26.10 and then I tried the last few betas (mostly because I bought an HRM-PRO and wanted the fixes fort raining load being properly calculated when using the Store & Forward) and am now on 27.00
My battery life is nowhere near what it was when I bought the watch, but that was 3 years ago now. But it hasn't changed much in the last year for me.
Not sure if it was using v26.xx or v27, but my 6XPS went from 75% to 1% in one day, using nothing different. Charged to 85% and it's been fine.
ever since on v27.0.
Yes, battery is draining around twice the rate it was on the last update, although not as rapidly as yours appears to be
Thanks for the heads up. I have now disabled auto update on my watch.
UPDATE: my battery life currently seems to be normal since posting this a couple of days ago. Obviously there's been no SW update since then, so no "fix" targeting my issue. So perhaps my observation isn't specific to v27. It's worth noting that I've sporadically observed this issue before, though never so quickly after a SW update so perhaps my attribution to v27 was premature and incorrect. I'll monitor the situation and try to update this thread if I observe anything significant.
Hi, I have the same issue. Ver 27.00 updated. Battery drains within a day from full to 60%. Fenix 6 4 Year old, no battery issue before. If battery drops under 50% watch swich off, usually whey using garmin pay. I tried soft, hard restart, restore factory settings. not helping at all. Watch is fine, should last longer than 4Y. Advice pls. thanks P.
Try to disable auto backup in the settings. Use the manual option once in a while
