Hi all, Garmin-Cody
What is the best method for tracking golf practice at the driving range (not on the golf course)?
Thanks,
Daniele
Hi all, Garmin-Cody
Thanks,
Daniele
Using the fenix 6, there are not any specific default apps developed to track golf at the driving range.
The only option available would be to create a custom activity > name it "Golf Practice", ..."Driving Range" , ...etc to record general information for the activity like a timer, heart rate, calories burned. Just make sure GPS is not being used, as you will be in the same spot hitting golf balls with no change in location to calculate any distance...and this will avoid any additional battery drain.
You can also copy another activity type and rename it to use the format of another app like "strength training" and you can manually record a rep to keep track of shots taken on the range. The strength activity app does not use GPS and allows users to manually enter reps...then start and stop sets. You can then stop and start a new set as you change clubs...but this would would not allow any specific clubs to be labeled, and would only be specific to basic manual tracking of amount of shots taken.
Link to the instructions showing how to copy or create a custom activity on the fenix 6 below for reference if needed:
