NEVER BUYING GARMIN AGAIN
I have owned Fenix 6X Sapphire since late 2019.  In late 2021 it stopped working randomly - the watch has never been abused or even exposed to water - I called up and Garmin was super helpful and shipped me a replacement (they said there was some sort of "known issue") within three days.  That watch was working fine until a week ago when it did the exact same thing.  Died completely.  Before anyone says "try this and that", I've done it all.  I've tried to soft and hard reset the device, checked the charging pins for the correct voltage etc. So I finally called Garmin support today and was told it needed to be updated (despite the watch updating wirelessly on an ongoing basis it doesn't do every update via wireless) Maybe the software should alert users to that especially since many don't even own traditional computers any longer.  I played along knowing that was just a red herring and as expected the unit would not power on when connected to my computer.  Support wants me to pay $160 to swap it for a "refurbished" watch, also with no warranty.  I pressed the issue on principle because a $700 watch shouldn't be disposable. I liked the watch so much I purchased two in 2019 and have one still sealed in the box (that probably won't work either now).  So I will be selling the new watch and never purchasing any Garmin devices again. If I hadn't received this bottom-notch customer service I was ready to spend $900 on a Fenix 7. Save me some money I suppose  I had a pair of air pods that were three years old and had a problem, Apple sent me a new pair overnight, I own a rifle that had an issue after ten years and Sig Sauer took it back and rebult it for free.  This is what quality support and customer service look like and Garmin should take note because this is what quality companies are doing. These things have been goofy/clunky from the start - the software was super buggy at first etc but I stuck with them because THEY WEREN'T APPLE then when they repaired this watch the first time I was impressed so I stayed.  Now I will tell everyone I know how absurd they are as a company and to never purchase any product with the Garmin name on it.  I guess I'll wear my five-year-old Suunto today because that has never had a problem.  Unreal.  Talk about missing the forest through the trees.
  • I liked the watch so much I purchased two in 2019 and have one still sealed in the box
    I wonder why a watch with a LiIon battery has been kept in a sealed box since 2019 ? But do you know that the battery discharges itself over time? Most likely it is now deeply discharged. If so, the battery is dead. Then the watch is unusable. Without ever having used it. Why would you do that?
  • that watch still isn’t opened.  I’m talking about the one I’ve been using since it was repaired in late 21.  When I purchased them I assumed that the battery was a user replaceable component and not soldered into the watch. I’m just going to throw the brand new one on eBay and unload it.  In reality, Garmin should replace the batter for free because I “technically” could have purchased it new this week for all they know.  If that’s you’re take away you’re missing my point.  $700 watch only works for 18 months tops and then they want to charge you $160 to swap it for a different repaired one with no guarantee how many cycles the battery in that watch has on it.  Great business model if you want to go out of business….
  • my 6 pro is 3 years old and i get close to 2 weeks battery. garmin watches have a pretty good Battey life compared to polar. it seems like polar watches after 2 years die but i could be wrong. it is not really garmin's fault about battery life. All other wearables have the same problem. it is true that if you do not use it, the battery will degrade. garmin has a 2-year warranty. that is pretty decent. $160 to get a new watch after that is not a bad deal. my 0.02
    • I have to ask again. Which watch do you want to sell? The watch that has been unused in a sealed box since 2019 ? If you have never taken this watch out of the box to charge it in between, it will certainly no longer be usable by now. The battery will be irreparably damaged by now.
  • Ok, I’ll try to type this slow so your smooth brain can maybe get it on the third trip around.  The watch in question was purchased in December 2019. I liked it very much and purchased another one in Spring 2020 (that one is the one that has not been opened).  The original failed inexplicably in late 2021 (less than 24 months from purchase).  Garmin hurriedly replaced that watch after less than 15 minutes of troubleshooting citing some “known issue.”  The replacement (received in early 2022) worked without issue until four days ago (oddly just about 24 months later) with the exact same symptom.  The fact that an $800 watch doesn’t last 24 months is unacceptable by any measure.  Apple still supports and provides updates for phones released 6+ years ago.  Also, when the iOS app indicates that updates are occurring on a regular basis without any mention of needing to be connected to a PC for “some” of them is also unacceptable. So if I purchase a 6X, which I can do today for $600 online and it arrives and doesn’t work because they don’t employ any control over the battery when it’s packed is unacceptable.  I’ve purchased $9 LED light strips that require me to pull a tab to activate the battery connection but Garmin does not? The fact that there isn’t a way for the user to purchase or obtain a battery replacement is unacceptable.  The battery is soldered to the circuit board, there is no good reason users aren’t allowed to remove the nine screws to access it and simply order an OEM battery and replace it.  This is intentional obsolescence.  I will be filing a complaint with out state consumer protection board and our attorney general. As far as the $160 is concerned…why would I spend $160 to obtain a used watch knowing that it is four year old technology, has a battery that won’t last 24 months and when it inevitably fails I cannot replace it? It’s pretty clear why Garmin’s market share hasn’t grown as fast as their competitors in this space.  It’s primitive technology backed by abysmal customer service.  If you want to buy the sealed 6X Sapphire LMK and $250 takes it.
    Moderator: Voicing dissatisfaction is welcome as long as we are civil and on topic. We will not allow abusive language and/or personal attacks against a user (volunteer moderators, forum members, or Garmin employees), or any other violations of the terms of use that you agreed to when signing up for the forum.
  • I’ve purchased $9 LED light strips that require me to pull a tab to activate the battery connection but Garmin does not?
    I'm sorry, I don't understand what you're trying to say with all this. Even Apple doesn't have a tab to activate the battery on its latest iphone. Tesla doesn't have a tab to activate the e-car either ;) To compare an LED strip with an ordinary battery to an electronic product with a LiIon battery is a bit strange from my point of view. Incidentally, Apple also says "Battery life depends on how you use your device and what settings you choose.".
    That's how it is with LiIon batteries. The service life is mainly determined by how the product is handled. How long you leave the device on the charger, at what temperature is it charged and used, do you always charge up to 100% and let the battery run down. The user is mainly responsible for how long a LiIon battery lasts.
  • In reality, Garmin should replace the batter for free because I “technically” could have purchased it new this week for all they know.
    Joy
  • I will be filing a complaint with out state consumer protection board and our attorney general.
    Please do let us know how you get on.
  • I’ve had a few Fenix and Forerunners replaced for free. I’m in Australia.
    Whenever the subject of me paying for a replacement for a faulty item is raised by Garmin, I quote our consumer law and ask to speak to a supervisor if the consultant feels they are unable to provide a free replacement.
    I’ve always received either a full refund or free replacement.
    There’s a ‘consumer guarantee’ in our consumer law and Garmin has always provided me excellent service beyond warranty.
    0 Former Member over 1 year ago
    Does not matter if you would have battery activation tab or not. LOL its the lithium chemistry that goes bad. Imagine it as a roll of paper and two magnets are wrapped on each side in the roll. the two differently charged magnets are attracting each other. In the batteries the chemichals will brake down and creating so called dendrites. They will grow towards, until they are touching just like the droplets in the caves. There you have a shorted circuit, they usually make a hole around themselves and the battery loses capacity as they are more and more of them. I have my fenix 6 pro solar since 2020 and still have a good 22days. Using it in the gym on run,for navigation, i am on beta software hence, some issues are present.
