Hi,
I need Downgrade my Fénix 6x with System File V26 to previous one. I have problems with the colors in some menús.
Someone has the System File previous to V26?
Someone knows how to Downgrade de software?
Regards
Manuel
Hi,
Regards
Manuel
Try to use a different version you downloaded from the "system backdate" file that you put in the Garmin folder in the watch when connected to the computer. Then disconnect the watch and it should offer…
Try a hard-reset after copying the GUPDATE.GCD into the Garmin folder.
1. switch off the clock
2. press and hold upper and lower right button simultaneously
3. switch on the clock
4. release upper right button…
No, it's a Fénix 6 Pro Sapphire, but not X. I thought they would share the same files but if that's not the case that certainly explains things, thanks for clarifying.
Btw, does anyone know…
Hello Farron. I am looking for the files too, for Fenix 6 pro (I need 25.91, because i have problème with 27.0). Thanks
Edited by Moderator: For your security, please avoid posting personal information, such as emails addresses, phone numbers, or physical addresses.
I had problems to downgrade my Fenix 6 Sapphire from 28.02 to 27.73. I always put the gupdate file from the SystemUpdate_27.73 folder into the garmin folder on the watch but nothing happend. After a few days I tried the gupdate file from the SystemBackdate_27.00 folder then the installation process could be startet. I therefore conclude that you first have to downgrade from 28.02 to version 27.00 before you can upgrade to 27.73. Now my hearthrate sensor was working again correctly with 27.73.
there is a search bar on the forum ;-)
= I share with you my Archives "Fenix 6 (Pro) files" https://mega.nz/folder/zVcmBAzC#NXczW8D0DG0KKZs0krPe9A // F6X my.hidrive.com/.../8z6g1evyp0 =
