Hi guys. Upgraded today to 26.00 version on fenix 6x pro, device cannot find any network (I have a few at home) - can you help me, please? Thanks in advance.
Change log for version 25.91 / Fixed an issue with manual Wifi syncs getting reported as failed on Pro devices.
version 26.00 The same error.I also have a version pro
No issue on my side with version 26. I have Fenix 6X Sapphire. During a few months it failed to synchronize thru WiFi but solved with V26.00.
Same for me, no issues with WiFi Syncing on my F6 Sapphire.
Have you simply upgrade device to 26.00? Any other actions taken? Upgrade was done via cable or wireless through phone? I'm trying to troubleshoot 'cause I have exactly the same situation looks like - after upgrade to 25.00 wifi connection has been lost, I did not upgrade firmware to any other versions until 26.00. Thanks.
The cable update is a priority. I thought it was enough for the air. Unfortunately it threw a mistake..F6 Sapphire - OK
Same here. Fenix 6x Pro. Wifi error when trying to connect "Wrong Password" or "Connection Failed".
Hi, the same WiFi issue for Fenix 6X Pro after update to V26.
Same issue here. I tried everything possible, as Garmin and other users stated. Anyone got a workaround in the meantime? Thanks
If the watch cannot find WiFi networks, check your WiFi software version. If it is 655.35, your WiFi is irreparable. Your watch will need to be replaced.
Thanks. It shows 4.01. So I'm stuck, no idea what to do.
I've already contacted Garmin support. Let's cross fingers...
