Hi all,
Quick one before I do a full reset.
I was out today on a long hike. Covered 22mi and when I got back I moved away from my phone whilst to was syncing (not thinking!) and although when I was back in range it completed the sync I noticed there was no elevation data/total ascent.
My legs are pretty sure that wasn't the case!
I figured it was maybe the bad sync so deleted the upload and grabbed the .fit file off the watch and uploaded that. Still a big fat '0' ascent.
Weird but then I have just done the 25.00 update so thought I wonder if its that. Checked a walk from earlier and that had no elevation data. In fact th least time the watch reordered any elevation data was 27th December 2022 (fw 24.10) then on the 30th (still fw 24.10) it no longer did until fw 24.81 then from fw 24.85 it stopped again and and indeed hasn't worked since.
I obviously haven't been being observant!
I haven't changed any settings so either something has gone wrong or something has broke. I am leaning towards gone wrong as my altimeter/barometer still give readings but for whatever reason nothing is going into the .fit file.
So I am hoping someone has any ideas I can try before I start resetting everything back to factory and start again 'fresh' if thats even possible.
Watch is a 6s Pro btw.
I have gone back on those activities missing the data in Connect and told it to use elevation correction but I would obviously prefer not to keep doing that and have things go back to working as they should.
Cheers.
