Cheers,
Where can I find firmware 24.00 for Fenix 6X Pro, or any older firmware?
Thnx in advance
Cheers,
Thnx in advance
Which model ?
Why do you want to rollback ?
Because 24.10 is killing my battery. On ver 24.00 was perfect
Because downgrade imply a reset of your watch setting, maybe you can try the latest Alpha before ?
https://forums.garmin.com/beta-program/fenix-6-series/f/announcement/319771/alpha-version-24-79
After update, always do a restart of your watch
- long press Light (upper left button) until shutdown
- short press same button to start your watch
I always restart my watch after update. Until 24.10 everything worked perfectly. After 24.10 update a several restarts and no improvement.
It's a suggestion, because i do not encounter it myself and i'm testing Alpha/Beta. For my personal understanding and search about battery drain, do you wear your watch over night ? tracking sleep ? Spo2 ?
6X files are hosted here by Maik if i remember correctly. For 6 Pro i have the files.
https://my.hidrive.com/share/8z6g1evyp0#$/
It can't find is tag, so i put a link to one of its post
Thnx for your effort
same problem here... from 24.00 working fine except 1 wallet instead of 2 upgraded to 24.10 with 2 wallets back but twice the battery drain. They fix one problem and create a new problem. You have 24.00 software for me? 6 sapphire THNX -
Had the wallet issue, installed alpha 24.79 but now - after more than a week using it - I have a battery drain. i went from 0,3% to more than 0,5% with my settings the same!!! Anyone has version 24.00 Fenix 6 sapphire for me?
Hi, I'm having the same issue of battery drain as many users of the fénix 6 pro after updating to 24.10. Could you share the version 24.00 (as you mentioned you had the files)? Many thanks in advance! Cheers!
Fenix 6 Pro and Sapphire are identical, but use it at your own risk.
https://drive.google.com/drive/folders/1UT7dXp-h0oEEovTEyZYyoiMwV-Lxlwh_?usp=share_link
