I just took advantage of a sale on the Fenix 6 Pro to upgrade from an Instinct 1. In general I'm quite satisfied with all the new features and capabilities of the F6pro.
The GPS however seems to be a giant leap backwards. I'm not talking about accuracy, but rather the ability of the GPS to lock in. On the Instinct, once the GPS got a lock into the satellite network it would generally hold it rock solid for the duration of the activity.
With the F6pro, the GPS keeps dropping contact with the satellite network every few minutes. When this happens the GPS usually locks in again a few moments later. This is an issue for two reasons. First, the constant buzzing on my wrist every time it locks or drops is very annoying. Second and more important, the periods when the GPS isn't locked reduces the recorded distance by 10% to 20%.(There's potentially a third issue that battery drain may increase when a GPS is searching for satellites.)
This happens in all sorts of weather ranging from cloudy, overcast to bright, clear sunshine. As I said, this never happened with the Instinct. This seems odd since the F6pro supposedly has a newer GPS chip and supports more GPS satellites. I've tried all combinations of satellite networks, GPS, GPS+GLONASS, GPS+GALILEO. Same issue in all cases.
I'm a new F6pro user so maybe I'm missing something obvious. I've read posts about GPS accuracy issues. They seem to be firmware related. So maybe there's hope my issue can be addressed. I'd appreciate it if some F6pro veterans could comment on whether my experience with the GPS is normal for this model or if it's something that a firmware release broke or that a future release might fix. Thanks.
