Holidays appearing Multiple Times on Calendar Widget
For starters, I have an iPhone and a Mac computer. So my Garmin takes the events from iCal in order to put them into my calendar widget. My issue is with holidays, seems that anytime there is a holiday it is listed 2-3 times depending on if iOS has the same holiday on their side as my 2 Google Cals for personal and work. I removed the Holidays from my work Google Cal altogether so now at most it's only listed twice, but was curious how to get it so there is only 1 event listed. I'm being picky here, it's just a little annoying for example that on Election Day it was listed 3 times at the top when I had other events I wanted to see when they were and scrolling through them.
Was curious to see if anyone had a workaround so that a Holiday only showed up once. I don't even use iCal or the iOS Calender really, but it won't let me delete their native Subscribed Holidays from the iOS application, unfortunately.
    It is not a really specific Fenix 6 question so you may have more luck in the Garmin Connect Mobile IOS forum. I have an Android phone and also did not want the standard events from Google calendar, the solution was using another calendar app that allows selective showing of one or more (synced) calendars, remove the national hollidays cal., and then removing the default Google calendar app from the apps that can show notifications, in the Connect app.
