I can see that there have been a fair number of similar issues raised in the past on Fenix 6 and other watches but none with exactly the same symptom.
I have a Fenix 6 Pro and an HRM Pro - had them for a couple of years and Forerunner 935 before that. About the end of May this year, the Fenix no longer made any changes to my Vo2 Max. Before that date my Vo2 Max would change quite regularly between, say low 50s to 58 in single number increments up or down after some runs depending on how fit I was - usually, a run ending with a Training status of Productive would result in an increase in Vo2 Max and a result of Unproductive would result in a drop. It tended to fluctuate often.
Since May, and I don't know if there was a software update or if I changed Max HR or what, my Vo2 Max has sat at 54 regardless of how well I've been running, how fit I feel, how fast or slow. I also noticed that the watch no longer flashes up my Performance Condition when running (about 5 minutes into the run usually) although I always have a Performance Condition showing after the run, which matches up with the Training Status usually - same as before. But no update to the Vo2 Max.
The watch has even updated my Max HR and Lactate Thresholds a couple of times during this period so it's obviously providing some analysis, but no update to Vo2 Max.
Lots of the other similar posts people have suggested that they're not doing something right, like not running long enough or hard enough or not setting the GPS right, using Trail Run or something, but that's not the case here. I didn't change anything in my running habits and the only thing that may have changed then or since is Max HR. I've checked the GPS settings and even set the "Run" activity back to defaults and checked settings. Can't see how it's different from before.
Nothing. I mean it doesn't affect my running or training status or load (I think), but it's a little disheartening when I feel my fitness is up not to get that little nudge. And it also makes me wonder if there's something else up.
Any useful ideas on what to check or do (from Garmin please or other users)?
Thanks...
