After update to sw v.23.00 Fenix 6x don't show sleep data after stop sleep manually.
Updated December 5th, 2022:
Engineering is looking into the issue further to resolve it.
For anyone that can replicate the issue of your sleep deleting if you manually end your sleep recorded for the…
I have the same problem on my Fenix 6 Pro. I don't really want to reset my watch to factory settings and loose all my activities on the watch without knowing if it works. Powering on and off does not solve…
Same Problem here. Reboot and soft reset (hard restart, however you want to call it), which I periodically and definitely always after a firmware update do, didn’t help. Really don’t feel like resetting…
Have just updated to v23 and not the exact same issue but no new sleep data was recorded only my on one showed up.
Since last update sleep tracking on my Fenix 6 Pro is crazy. Both yesterday and today it said I slept 22-23 hours which is incorrect because I slept 6-7 hours. That's also totally ruining the new HRV experience because it also took wrong info from sleep tracking. Everything I did, I did as I was doing before update. When i wake up, I manually finish sleeping on my watch and that's all. Also, I have to say that sleeping time in my app is set between 0.00 and 23.59. I did that because I work in three shifts, but I never had any problems with that on both my Garmin watches (Vivoactive 4 and now Fenix 6). Please, help!
I don't know does it work normally if you don't stop it manually, and if you let Garmin to automatically recognize it.
No recording on the watch or it just didn't sync to GC? Did you manually stop recording?
It's recorded on the watch and synced to GC. But it's totally wrong. Sleep duration is 21h (both on the watch and in GC), which is obviously not correct. I did manually stop recording. I'm doing everything the same way I was doing for last two years.
I work shifts too, but I still have set sleeping time as 22:00 - 06:00. But yeah, sleeptime recognition isn't the same since 23.00...
This was meant for Nick.
Oh, sorry.
Yeah, but at least once a week I work a night shift too and then I sleep from 6-7 to 12-13. It was alright until update. Hope they'll fix it soon.
I have found that leaving it with 22:00 - 06:00 works even when I go to bed after or around 06:00. Well, at least pre 23.00... Now when I go to bed late/early, it sometimes doesn't track the first hours...
