set up target in swimrun mode
Hello,
after many years  of running i want to start to add some swim exercises to my training. There is the swimrun mode on the Fenix 6 Pro that i have but i don't find an option to set up the distances. In running mode i can go in the running mode, by push "up Menu" to "set up target" and select how long i want to run.
I would like to set up 5km running, 1000m swimming and then 5km running again for example.
I there any possibility to set up this? Would be easier when the watch tells me when the swimming part is over.
Maybe someone knows how that will work
  • I don't think you can set up the targets like that in swimrun. What might be best for you if you want to keep the run, swim, run, as a single activity would be to switch sports without saving each time by using a Hot Key. You can then select a custom workout at the start of each activity if you want guidance for the specific distances.
