Fenix 7 pro and Polar H10
I am having troubles pairing the watch and app at the same time. I do have the 2 Bluetooth options picked so it should work just fine but when pairing mode in the app it shows the Fenix 7 and not the HR monitor. What am I doing wrong here? Thank you
  • This isn't the right forum. I'm confused, though. What are you trying to do and why?
    You can't "pair" the H10 with Garmin Connect since it's not a Garmin product. You can, however, connect the H10 to your Fenix as an external HRM.
    Pairing Your Wireless Sensors
    The first time you connect a wireless sensor to your device using ANT‍+® or Bluetooth® technology, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
    1. If you are pairing a heart rate monitor, put on the heart rate monitor.
      The heart rate monitor does not send or receive data until you put it on.
    2. Bring the device within 3 m (10 ft.) of the sensor.
      NOTE: Stay 10 m (33 ft.) away from other wireless sensors while pairing.
    3. Hold MENU.
    4. Select Sensors & Accessories > Add New.
    5. Select an option:
      • Select Search All Sensors.
      • Select your sensor type.
      After the sensor is paired with your device, the sensor status changes from Searching to Connected. Sensor data appears in the data screen loop or a custom data field.
  • What forum am I on? Anyhow I fixed the device
    Thank you
