Software 21.00 Issues
After the Software 21.00 update, my Fenix is stuck on "Loading Maps". When the watch decides to skip this step nothing works on  the watch besides time (which is 10min behind I guess without the gps functionality).
  • The battery died twice in the last
  • 24 hoursThe optical HR is not working
  • Maps is not loading as mentioned above / GPS not working
  • Sleep data not recording
  • ABC sensors not working
  • etc
  • etc
  • etc
How can a watch work perfectly, and then after a software update the watch has NO FUNCTIONALITY. Do the people at Garmin not test the software before they release it? It seems when they try to fix something they end up braking other things.
I'm not happy at all, can you please advise what to do or sort this issue out ASAP. I have switched the device on and off a few times, but with no positive results.
Regards, Pierre Viljoen
  • My one is Fenix 6 pro, it is the similar  issue as you have after V21.0 update, the battery drained much fast than before, one night drained 50%  with fully charged. sometimes, battery died, it has to recharged again, V21.0 software sucks!
  • It seems that the new Alpha 21.71 has fixed the issue with the workouts that could not be deleted via the watch.
    Change log for version 21.71 (changes since v21.00):
    Fixed an issue where user could not delete a Strength workout from device.
    Fixed an issue with Metronome hot key not working in the Walk activity.
    Fixed issue in the Jumpmaster activity where the listed elevation data would not properly update.
    Fixed an issue that could prevent device from booting up properly.
  • I'm experiencing some issues too:
     - The battery drains as fast al 20-30% day without activities.
    -  Trying to open the sleep widget restarts the watch.
    Factory reset didn't fix anything.
  • I have problems with accumulated ascend and descend, it gives 1.5x than what shoul do. Before firmare update was accurate.
  • I have some similar issues.
    Sensors randomly disconnecting.
    Wrist HR even worse at picking up HR than before.
    Phone and watch don't stay connected.
    Battery life is terrible. 20% used for a 30 min run.
    Garmin, if you're going to use your customers in place of a Quality Assurance process, at least provide us a simple mechanism to rollback to older firmware versions.
  • Issues with Battery consumption during excercise is a big no no.
    Any increase in Battery consumption recorded in Beta testing should automatically reject project & changes.
    Product should be improved & optimised - not other way around.
    Issue 1 : Battery consumption is the biggest problem for me since last 2 upgrades.
    I cannot do more than 5 hours cycle as drains battery to 0. Not doing anything crazy - just GPS navigation + 2 external sensors
    Issue 2 : Problem with multiple BT connection. Not sure if the firmware of connectivity caused that- but since last 2 upgrades i have problem connecting and displaying data from my Cad / Spd sensor. Once i switched to ANT+ no issues, when i get back to BT - Establishing Connection with no problem but not showing any data.
    Issue 3 : GPS is way slower than it used to be. When navigating i get turn by turn (Set to follow route)
    and not only that i don't get updates on distance to that turn (never worked for me) but i get prompts after my turn - as GPS got "frozen" for few seconds"
    Issue 4 : Another FW rollout and yet another pack of bugs and issues. I would preffer to wait longer for new releases but have properly tested release than having so much trouble with it.
    And here's the thing. Coming from Suunto to Garmin Environment - now just wanted to jump to Wahoo instead
    Just to have full spectrum who's doing better Smiley
    Suunto - annoys me with Facebook SDK approach, anyway - who knows what brings future for not so anymore Finnish brand...
    Garmin - God damn - less upgrades, more testing and more stable releases !
  • After hard reset my 6X cannot find any Wi-fi networks. Could be related.
  • I got stuck in airplane mode, I managed to disable it by enabling battery save mode, and now I'm stuck in battery save mode and there is no way to disable it!!
