FIXED!!!!
Hay, my tactix delta firmware is on 20.85 and i have battery drain (normal with software 20.42 15 days an now on 20.85 2 days max!!!) also test with 20.85 and 20.50.and 20.51 (test the all and all 2 days max!!)
Can anybody tell me how to do it? i try this with 20.42 over my 20.85 but it's not working:
Installation Instructions
- Download and unzip Fenix6xPro_***Beta.zip.
- Place the gupdate.gcd file, found in the System_v*** folder, into the \GARMIN folder of the device.
- If there is a Sensor Hub_v*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
- If there is a GPS_v*** folder, place the gupXXXX.gcd (or 006B310700.GCD) file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
- If there is a ANT_BLE_BT_v*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
- Disconnect from your computer and proceed through the update.
- If you would like to revert to the last public release software, drop the gupdate.gcd file found in the System_Backdate_v*** folder in the \GARMIN directory NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
I want back to this version...
thanks Robin
