My Garmin 6 has had a lot of battery issues, and I was beginning to think that my battery was old since it felt like it only got worse and worse. My battery discharge could be anything between 2 - 10% per hour as you can see in the graph below (Charge 3). However, now it's completely fixed and my Garmin 6s Pro is back to around 9 days of battery time! Here's what I did. It really helped me a ton, and I hope it can solve someone elses battery issues as well!
Here's what I did:
- First thing I did is that I connected my watch to my computer and deleted all the folders and files I was able to delete. I then did a complete restart of the watch, and after that a reset. This did not solve anything, and I still had a horrible battery time after that. However, some people reported that it helped, since the bad battery could be due to corrupt files.
- The next thing I did which indeed did help, is that I tried to disable the phone connection from within my watch. Either disconnecting, or using airplane mode should work. My battery time was improved straight away, and I realized that it was something odd with the connection between the phone and the watch. Some people also claimed that an old phone which is attempting to connect to the watch could seriously impact the battery time.
- I uninstalled Garmin Connect and Connect IQ, and removed my Garmin 6s Pro from my phones bluetooth connection, and then reinstalled everything, and reconnected my Garmin 6s Pro to the phone.
- The watch was then at around 90%, and you can see the result after this in the graph!
So if you are having trouble with your battery discharge, it could be due to:
- Corrupt files on the watch - Remove all files, restart and reinstall
- Bad connection between your current phone and the watch - Uninstall everything, remove bluetooth connection and reinstall/reconnect
- An old phone which is attempting to connect to your watch - Make sure you remove bluetooth connections from all phones which are not your primary phone.
