Fenix 6 Series - 20.82 Public Beta
Hello Fenix 6 customers,
Our next beta version for the Fenix 6 series is now available!
Please email the Garmin Outdoor Quality Team if you find issues in software after installing this update: [email protected]
If you’ve participated in the Fenix 6 Beta Program previously, you’ll notice a few changes from how we have managed this in the past. And further down the line, we’ll have some additional improvements to the Beta Program (more on that later!) Notably, this forum post is now the primary resource for reading the change log notes – they are not available on another webpage. (There will be more options for viewing change logs after we implement the additional improvements to our beta program.)
The links to download the software update are listed below. Select the link specific to your watch model. Please note that your computer will download a .zip file when you open this link. This zip contains the software update, as well as a folder with the file necessary for backdating software, and instructions for this process if you choose to do so. Remember, backdating software will reset all settings.
Use these links to download the zip for your watch to update to version 20.82:
Change Log for version 20.82 (changes since 20.50):
  • Added support for Connect IQ system 5.
  • Added new alert to display after this SW update to inform user that wifi networks configured to WEP security are no longer supported. (Pro Models)
  • Added a new tip to inform the user each time a new emergency contact is added from Garmin Connect.
  • Added a new tip that will recommend the user to reboot the device if the GPS is unresponsive while waiting for a fix before an activity.
  • Added the Endurance Horseback Riding Activity.
  • Added the new Easyhunt feature to the DogTrack app.
  • Added the Resting Heartrate True-Up feature. RHR data now gets trued-up so that all devices tied to the same account will have the same RHR value.
  • Added enhanced strength functionality, which includes an improved workout preview with a map of muscles that will be used, improved UI in free mode and workouts, and improvements to the rep and weight editing experience.
  • Added animation to progress arc when viewing Intensity Minutes widget.
  • Updated incident detection to better distinguish between supported and unsupported activities.
  • Improvements made to on-device sleep detection and sleep staging.
  • Improvements made to Run/Idle detection algorithm, particularly when detecting when the user has stopped.
  • Fixed an issue when setting timer alerts on the Track Run activity.
  • Fixed an issue where one could preview workout videos for user created workouts. (Pro Models)
  • Fixed an issue where animations for some Garmin-created workouts did not display during a workout. (Pro Models)
  • Fixed an issue where inReach menus are available while in Expedition mode. These menus are no longer available when in Expedition mode.
  • Fixed an issue where the time of day would intermittently get cut off on the lap alert.
  • Fixed an issue where the lap banner would not go away when on the music player.
  • Fixed an intermittent issue where the backlight would not turn off in Expedition mode.
  • Fixed an intermittent issue where graphical data fields would not render properly.
  • Fixed an intermittent issue where the wifi setup page would show the same network multiple times. (Pro Models)
  • Fixed slight UI delay when accessing widgets from the watch face.
  • Fixed UI issue on the golf last round widget.
  • Connect IQ stability improvements and bug fixes.
  • Other minor improvements and bug fixes.
Instructions for updating software:
  1. Download the .zip specific to your watch, using the links above.
  2. Connect the watch to your computer.
  3. Copy the included gupdate.gcd file (from the System_x.xx folder) to the Primary\Garmin folder on your watch.
  4. If there is a Sensor Hub_v*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
  5. If there is a ANT_BT_BLE_v*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
  6. Disconnect the watch from the computer and it will prompt you to update software.
After updating, your watch will be running the following software versions. These can be confirmed on the Menu – System – About pages. New versions are indicated in red.
System Software: 20.82
GPS: 5.30
Sensor Hub: 18.00
ANT/BLE/BT (Pro models): 6.15 *If you have been participating in the Beta Program, you may already have this sw
ANT/BLE (non-Pro models): 3.00
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not compatible for APAC region devices.
  • Have you got the most recent version of the widget?
    May not be relevant to your issue but the widget was updated to version 1.2.4 on 2022-03-28.
    Pity that the Device Usage widget is not included.
  • Downloaded and installed without issue, thank you.
    As a bimodal sleeper, I'll be particularly interested to review sleep tracking changes to see if it can reliably spot awake time of a couple of hours between sleeps. I suspect that I'll still have to rely on body battery to identify daytime naps. Fingers crossed that it doesn't mess with my 'change activity' logging.
    A note to devs: Although my Fenix 6X Pro tracks conventional cross training activities related to my athletics sprint training very well, I often use an IQ dance app to track 3-4 hour dance events. There doesn't appear to be any acknowledgement of a 600-800 calorie activity deficit and the impact / recovery that that might have.
  • 26l ... I'd never be able to leave the house!
    Was looking forward to a fix for the min and max indications on the barometer widget (missing when difference > 10 Mbar), but I guess I'll have to wait a bit longer for that.
    Resting HR is bouncing up and down - I have no other devices sycning that record HR for 'true up' to apply
    Started at 46 today (from previous firmware)
    https://ibb.co/DWT1dYV
    Then moved up to 47
    https://ibb.co/1ffqnKd
    Then DOWN again to 46
    https://ibb.co/ydStLZ7
    Then UP again to 47
    https://ibb.co/cXXNTR5
    You can see the changes timestamped top right from my phone clock
  • Weird, my Resting HR hasn't moved since the morning (synced several times) and still shows 45
  • Would actually be very nice to have also a "body battery" (and maybe connected stress history) true up.... would really make it possible to use multiple devices for sports, casual wearing and sleep tracking. possibly bit challenging who is the device that "wins" Smiley but probably workable
  • Something's surely fishy here (and it's ok, it's a beta) but just rechecked out of curiosity... Without doing anything colors are there now on my Fenix 6 base, but not yet on my Fenix 6x pro solar...
    Oh well, they will come, looks like a cool thing to show off about Smiley
  • you will be able, but only after Garmin releases the new devices to the SDK so developers will be able to compile their app to Fenix6 with CIQ 3.3.1, Until then you'll only be able to do sideload if you compile an app for yourself. The same delay was with FR245 a few weeks ago.
